Key Ring Led?????
Old Jul 14, 2005 | 01:59 PM
ruffrida24444
Key Ring Led?????
Anyone Who Did Leds In Their Car What Did You Use For The Key Ring??? Did U Buy A Led Bulb For There From Somewhere Or Solder A Led In There?? Any Info Will Help Thanks
Old Jul 14, 2005 | 03:18 PM
kbmaxima's Avatar
how do u type like that? doesn't it get annoying and tiring?
all u have to do is put an led into the existing bulb holder. This requires u taking apart the kick panel and the covers going around the steering wheel. if u can stomach doing that, then you're set.
Old Jul 14, 2005 | 03:22 PM
sunten1
Thats what happens when you type in all CAPS
Old Jul 14, 2005 | 03:46 PM
NmexMAX's Avatar
dot dot dot ...
This is a thread ...
Old Jul 14, 2005 | 04:27 PM
killerVQ30DE's Avatar
First locate your capslock
Why would you want to type in caps in the first place
Old Jul 14, 2005 | 05:44 PM
ruffrida24444
i never knew typing in caps was such a big deal................
i just happen to have it on and when i was done typing i didnt feel like typing all that $hit over again........
Old Jul 14, 2005 | 05:51 PM
kbmaxima's Avatar
excuses excuses. if you had the caps on, IT WOULD BE TYPED OUT LIKE THIS: and Not Like This. Seriously, Your Caps Lock Key And Shift Keys Must Be Worn To Shiet.
but yea. the keyring mod is easy. once u take apart the dash, you'll see the keyring part. follow the wire, disconnect. bring it in side with u. place an led in place of the bulb. go back to your car, test it out, voila. o yea, always rememeber to disconnect the neg. on ur battery. JUST in case.
Old Jul 14, 2005 | 05:52 PM
cefiro8701's Avatar
haha...yeah...some orgers are freakin princesses who complain and make big deals about everything...
the answer for ur question is simple...
open up ur steering column...take out that part..the bulb will have a green or blue condom looking dealie...(i think its a 194...i read this from a 5th genner)..get a sharpie and color that whatever color u want...put everything back together and ur done...
Old Jul 14, 2005 | 05:55 PM
cefiro8701's Avatar
heres the link
http://forums.maxima.org/showpost.ph...3&postcount=90
Old Jul 14, 2005 | 06:17 PM
ruffrida24444
now i see wut u guys thought i did but when i typed in all caps fo rthe post thats wut it did...
thanks tho guys. i just thought i might be able to find a bulb that plugged rite in. its smaller than a 194 tho. i'll just solder an led in
Old Jul 14, 2005 | 06:28 PM
ruffrida24444
cefiro did that blue bulb dull at all over time??? and u only put one in there correct?? thanks
Old Jul 14, 2005 | 06:54 PM
kbmaxima's Avatar
don't sharpie. for 4th gens its #74 bulb. just replace it with a 5mm or 3mm led. the sharpie is said to fade after time.
Old Jul 14, 2005 | 08:11 PM
cefiro8701's Avatar
it wasnt me...it was some guy with a 5th gen...
im gonna do this soon though...don't really car if it fades...so long as its not green anymore...that mess was ugly
Old Jul 14, 2005 | 08:40 PM
G4nismo's Avatar
i concur dfgsdfgsadfgadgdfaadsfdfsa
Old Jul 15, 2005 | 01:08 AM
aznprid972's Avatar
I used to color mine blue with a sharpie and it faded into a purple looking color. Then I got smart and finally put a white led inside and TADA.... I am proud of my work.
Old Jul 15, 2005 | 01:39 AM
cefiro8701's Avatar
i agree shallow and pendantic...
Old Jul 15, 2005 | 04:10 AM
cefiro8701's Avatar
theres a blue LED ign ring on the FORSALE forums and the guy's selling it for 12 shipped...i say take it...
Old Apr 24, 2011 | 06:58 PM
maxima_driver's Avatar
how do i remove the keyring? once i get the "cover" off i cannot remove the plastic peice that the led is behind. maybe im doing it wrong? help w/ pics would be much appreciated!
Old Apr 24, 2011 | 08:00 PM
LtnMAXX's Avatar
SERIOUSLY???
Old Apr 24, 2011 | 08:05 PM
tigersharkdude's Avatar
If the 4th gen is like the 7th gen, all you should have to do IIRC is unclip the electrical connector and pull it off
Old Apr 24, 2011 | 08:22 PM
chrome91's Avatar
2005, back in the day lol
Old Apr 24, 2011 | 09:58 PM
Old Apr 28, 2011 | 03:55 AM
HandsonMaxima.'s Avatar
This is why Maxima.org is still my Homepage after a year of being out of the game, never change 4th gen forum.
That and the fact Craigslist-Maxima is my second homepage..
Old May 10, 2011 | 09:16 PM
TibTibs's Avatar
The key ring pops right off if you just give it a little wiggle, the connector is about 6 inches back. As for the LED, the old one was hell to get out, ended up shattering it into a million pieces with a micro-screwdriver. I put a blue T5 (Which is the same as a #74) SMD LED in mine, fit perfectly.
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
