View Poll Results: How happy are you with your coilovers?
JIC - Happy
21.88%
KSport - Happy
6.25%
D2 - Happy
18.75%
Other - Happy
21.88%
JIC - Unhappy
3.13%
KSport - Unhappy
3.13%
D2 - Unhappy
15.63%
Other - Unhappy
9.38%
Voters: 32. You may not vote on this poll
POLL: Coilover Setups - Happy or Unhappy
great....all i need is another thread to convince me to drop a lot of money on coilovers instead of shocks/springs. i was seriously about to order shocks/springs this weekend too...
i like mine but just found out that one of my CV boots is busted and to replace my axle will be around $600-$700. Not too happy about this, and have a feeling this wouldn't have happened if my car was still on stock suspension
Originally Posted by Ammi
It might have been bad luck. My car been dropped over 2" for years w/out any problems
Originally Posted by $tillenmax2k
Yes, it would have happened on stock suspension. The axle plus labor should not be more than $200.
depends an axle will end up costing more than 200 dollars in itself, whoever said that probably just had a boot replaced. price also depends on where you get the axle and who installs it for you but i would say that im pretty sure its gonna run you more than 200 dollars for a new axle installed.
actually with the D2's I had my car dropped about 4-5" in the front and about 3" in the back. Maybe my CV boot was going to split anyways, but oh well....what can you do. I know when you start messing with things you always end up spending more...it's worth it though....
not to hi-jack but how high r ur guys wheel wells from the ground, i thought i was rahter low, but it sounds like some of u are way lower than me, mine are 24 inches front and rear form the ground to the middle of the bottom of the well, and im runnin the stock 17s with 45 series rubber
yes i know that means my rear is set higher than the front, thats how i like it!
tell me how you drove around w/ a 5" drop. How did you manage to turn w/ your wheels tucked in?
raised the car up a little.
I' ve been running on D2 for the last 2 months, the car is litterally on rails. I had to re-thigh the colar few time but other than that the car is very stable in every condition. The only drawback are the flimsy rubber that come with the D2, and few rattles that appear because the ride is much stiffer than stock. When I compare to a stock Maxima side to side with mine I'm like 5-6 inches lower. From the front subframe there is about only 3-4 inches of ground clearance.
that's crazy how you guys get so low. for some reason i thought going any lower than 25 wasn't possible with most coilovers (besides d2's) since they claim to only lower up to 3", and i thought our front ends sit higher than 28" stock.. i thought i was stretching my imagination when i was hoping for 25" all around w/o setting it at the lowest setting...
actually i voted unhappy but now that i have all my little quirks worked out with the D2's I love them. Sure they a re a little uncomfortable, but the look and handling more than make up for the rough ride over bumps!! I think this would be one of the best mods out there...
Originally Posted by ighettoboyi
you cut your maxspeeds??
nah actually when i was new on the .org i saw them for $40 and said, "wow what a great deal!" I dont regret it though since the ride isnt too bad... ive been in worse.
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
