Clicking noises when braking
So for awhile now my car makes these pretty loud clicking noises when braking. I changed all of my brake pads not long ago, so I was wondering if anyone had this similar problem and could give me any advice to fix it. Thanks
I may be having a similar problem. And it happens sometimes, not all. When I step on the brake, I get one clean "snap" sound. It's loud. I checked my boots and they're not cracked or leaking. So it's not the axle. There's definately something loose under there though. When I go over a large bump, I hear a clunking sound also. Maybe I have two problems? No idea what it is. I'm gonna take it to the shop this week and find out what the prob is. I can fix things if I know what the hell it is. I'm just bad at diag.
Edit: The sound comes from my driver side suspension. I figure I broke something when I took one too many high speed off ramps. All that pressure on the front driver's side, had to have tore up something. I'll find out what the hell it is and post the results in a few days.
Just came back from my mechanic concerning the noise I had when braking.^^^^
Turned out to be the pads moving around. He applied a blue substance to the back of the pads. It fixed the problem. He told me it was a "glue" of some sorts. I dunno, all I know is it don't go "SNAP!!" when I apply the brake.
Hopefully this is the problem you're having. It was a quick and cheap fix. He charged me 20 bucks to diag and fix it. I love that guy.
Originally Posted by Lynch
my car squeaks when i apply brakes at a certain foot pressure. repair guys said it doesn't need new pads--- any help?
If the repair guy says your brakes are fine, they're fine. Brakes squeak sometimes. As long as it stops, that's all that matters.
This may not be of much help but squeaking can be caused by many things. I'm willing to bet one of the most common causes are dirty rotors. They simply get dirty from dirt, debri, and brake dust. You can either buy brake cleaner or use intake cleaner to clean them up. I'm going into the garage right now to spray some intake cleaner on mine actually since they've gotten a little noisy over the past few weeks
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
