*help* dealer can't find it!!!
Old Jul 21, 2005 | 08:13 PM
VTmaximaVT's Avatar
hi,
my car was at the dealer whole day today, got the catalyst support bracket
replaced (rattling sound during light acceleration is gone), all brake rotors
resurfaced.
the thing is that they can't figure out what makes the knocking sound from
the back. they looked at it last week and today and still don't know what
causes it. they told me to bring it back on tues.
I get the knocking sound from the back when only one of the rear wheel goes
over a bump. anybody had this problem and got it fixed?
Old Jul 21, 2005 | 08:15 PM
blackpaladin67's Avatar
Let that poor bastard out of the boot ....LOL
or look at that rear strut mount bolt on the noisy side.
Old Jul 21, 2005 | 08:27 PM
NismoMax80's Avatar
SuPeRmOd
i hope it's not a bad shock. but, "one wheel going over a bump" the first thing checked should be the rear shocks.
Old Jul 22, 2005 | 04:03 AM
VTmaximaVT's Avatar
i told them to check the rear shocks when i was there for second time. either shocks are ok or they're not listening to me...
thanks guys for your inputs.
Old Jul 22, 2005 | 04:07 AM
SLuxury's Avatar
Have you checked to see if you're spare tire is moving around?
I know it sounds dumb, but throwing out possibilities...
Old Jul 22, 2005 | 06:55 AM
VTmaximaVT's Avatar
haha, i'll check the spare tire, but i doubt that's the cause
it sounds like something's knocking or popping.
thanks guys.
Old Jul 22, 2005 | 07:02 AM
CanadianMoFo's Avatar
Take it right out along with the jack and everything in the trunk that can be removed.
CM
Old Jul 22, 2005 | 07:23 AM
thecritik's Avatar
Strut
Sounds like either a rear strut is bad and isn't dampening well or the bolt at the top of the strut is banging against something. Both of which I've experienced in another vehicle. Good luck with Service though ... They're always fun.
Old Jul 22, 2005 | 07:53 AM
Maxium's Avatar
Could be you're just low on blinker fluid :-)
Old Jul 22, 2005 | 08:49 AM
Could be the infamous rear deck rattle too. As the frame flexes the brake light cover may bang against the glass. See the sticky or other threads in that regard. I did the sock fix, and later switched to a couple small clear rubber feets between the window and the 3rd brake light. Narry a rattle from the rear deck after that.
Old Jul 22, 2005 | 08:52 AM
92 Max's Avatar
Things that go Thump in the back
I remember reading here about someone who had a thump in the back. They dropped the rear seats and had someone drive them around until they could locate the thump. It was some support member in the back under the rear shelf. As I recall they put a sheet metal screw into it to stop it from banging against the bottom of the shelf. I'm doing this from memory, so you may want to look back in the earlier threads or in the red listing at the top of the 2004-2005 list. Anyway the diagnostic procedure sounds like it would work. (have someone else drive while you're in the trunk, it's safer).
Old Jul 22, 2005 | 09:03 AM
kamski's Avatar
.org extraordinaire
yep
You got it right on the money, it was my GF driving while i found the rattle. I used a self tapping screw to bolt the two sheet metal pieces together. Here is the link to the thread.
http://www.forums.maxima.org/showthread.php?t=415767
Good Luck Bro,
Kam
Old Jul 22, 2005 | 01:05 PM
VTmaximaVT's Avatar
thanks alot guys for your inputs,
however, rattle is not my case, i just get one short knocking, popping sound. not rattling at all. yes, just very short sound once. i dunno how to explain...hmmm.
Old Jul 26, 2005 | 07:02 AM
VTmaximaVT's Avatar
just dropped off my car at the dealer, they said it's gonna take some time to
find exact location of the sound with some kinda sensors they have. they
gave me a 01 sentra as a loaner....lol well better than nothing.
i hope they find what makes the knocking sound this time and get it fixed.
Old Jul 26, 2005 | 09:52 AM
jjtricket's Avatar
Don't you just love it when they give you some ugly duckling loaner?
Old Jul 26, 2005 | 05:47 PM
VTmaximaVT's Avatar
lol, i don't even care if it's ugly or not, cuz it's not like i'm gonna drive it
for weeks. just one day, i don't care...
seriously...this 01 Sentra GXE lacks in power...with AC on, it just doesn't
wanna accelerate...i miss my max already.
Old Jul 26, 2005 | 09:35 PM
04RedOpMax's Avatar
Maxima of the Month Winner
Could be the rear sway bar. I have heard that it has come loose on some cars.
Old Jul 27, 2005 | 06:17 AM
VTmaximaVT's Avatar
maybe...but i heard it even before i installed stillen sway bar, I was hoping stillen sway bar could fix the problem. After installing the stillen sway bar,
it's still the same. i didn't have a torque wrench when i installed the rsb.
but i think i tightened it properly. the dealer hasn't called me yet.
i will keep you updated.
thanks guys.
Old Jul 27, 2005 | 06:08 PM
Crazy-J's Avatar
I had the same knock in my sentra. It ended up being that the exhaust was off one of it's hanger. Typically it's the simple stupid stuff and we overlook it.
Oh and Sentra's aren't too bad. I have the best of both worlds! haha!
Old Jul 27, 2005 | 07:15 PM
ranjittx's Avatar
I have the same exact problem being talked about in this post. I told the dealer about it and they deemed my shocks to be bad. They replaced them but the sound is still there. It only occurs when going over bumps.
Old Jul 27, 2005 | 11:03 PM
VTmaximaVT's Avatar
my car's still at the dealer, well...i'm trying to be patient.
your VQed spec V isn't, my loaner GXE is...
hey Crazy-J, is there a thread about your car? pics?
what #s does your spec v pull at the track? or on the dyno?
Old Jul 28, 2005 | 06:35 AM
leroygreen's Avatar
do you have the rear window shade? Mine does and there is often a knock during bumps that is caused by the support brackets for the rear window shade.
Old Jul 28, 2005 | 08:20 AM
VTmaximaVT's Avatar
nope...no rear shade.
it's a deep knocking sound, it's definately not from interior cabin.
still at the dealer. i'll keep you guys updated as soon as i get some info
from the dealer.
Old Aug 2, 2005 | 10:13 AM
VTmaximaVT's Avatar
it's been exactly a week since I dropped off my max at the dealer for rear knocking sound, and they still have my max. they say they can't find what
causes the sound. (either they can't find, or they're not finding)
last time I checked, last fri, they said they can't find it and it's up to me
to pick up the car or leave it with them for a while.
If they say they can't find and tell me to pick it up, what should i do?
just live with it?
Old Aug 2, 2005 | 10:44 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
That's exactly what I was thinking, TRUNK MONKEY wants out...
Old Aug 2, 2005 | 07:20 PM
Crazy-J's Avatar
Once I get some updated pics of the motor swap and all that I'll post something up. Just I wouldn't know where the hel to post it! lol!
John
Old Aug 12, 2005 | 02:33 AM
VTmaximaVT's Avatar
FINALLY GOT MY CAR BACK TODAY AFTER 3 WEEKS OF BEING PATIENT!
ok, I finally got it, no more knocking sound. I was pretty sure it came from suspension. but i was wrong. they replaced/fixed sunroof stuff, i'm not sure. they couldn't print out the receipt so they promised me to mail it to me later.
when i read it briefly, it said sunroof or something and removing headliner and blah blah, didn't read it throughly. i'll update it as soon as i get the mail.
oh, when i got it back, Airbag light was flashing...
also it seems like shimmy is developing. I get steering wheel vibration at 60-80mph. i'm not sure on this one, i still gotta check tire balancing and stuff.
i still love my max, but i think i'm gettting tired of visiting dealers. is it time for a new car?
Johnny9595
Aug 21, 2015 09:18 AM
kirkhilles
Aug 8, 2015 10:53 AM
Habibshaib
Aug 6, 2015 01:19 PM
BassAddictJ
Aug 4, 2015 11:38 AM
