good buy?
Old May 22, 2001 | 05:53 PM
mazda_speedstar's Avatar
well im currently an owner of a 1994 MX6 but now im lookinf for another car and i have some questions about 1997 automatic GLE i found... well it has 61000 km on it, its automatic, fully loaded with sunroof, tan leather seats, bose system etc and its green... the price theyre asking is $19 500... is that a good deal? also it there any problems with the 1997 GLES i should look out for? any recalls? also what should i have them replace at this time in the cars life? basically what should i be aware of in the 1997 models engine wise? Thnx alot.. peas
Old May 22, 2001 | 06:47 PM
redmaxpa007's Avatar
i SeE what you did therE
i do not think so...
i owe 16,500 and i have a 99 se-l
i have everything, but climate control and leather
Old May 22, 2001 | 06:54 PM
Ravq's Avatar
Check out the value of your car:
http://www.edmunds.com/used/1997/nis...an/prices.html
I think $19,500 is a little steep.
Old May 22, 2001 | 06:57 PM
1 more thing...
19 500 canadian dollars... so are there any problems such as the tranny, or intercooler, brakes etc.. basically anything i should look out for and what should i ask the dealer to change at 60 000 km? thnx again
Old May 22, 2001 | 07:01 PM
what is the US to canadian conversion??
Old May 22, 2001 | 07:03 PM
Ravq's Avatar
Oops ...I should have known that it was in Canadian dollars from the 61000km....So what is the conversion anyway?
Old May 22, 2001 | 07:07 PM
mAdD MAX's Avatar
For almost $19.5K CDN? That seems reasonable! But does that include 15% tax?? Even then..its not that bad!
For our American neighbours, using a rate of $1 CDN = $0.65US, the price would be approx. $13K US.
You know what sucks about this whole exchange rate? You guys call the WRX so cheap cause its around $25K US, in CDN money its around $37K CDN, that's a whole lot a money...doesn't sound so cheap anymore now does it?
Old May 22, 2001 | 07:49 PM
thnx but...
My other question still didnt get answered... are there any problems or recalls i should be aware of before i buy this car? My mx6 gave me a lot of problems such as the distributor, calipers and tranny so i just wanna make sure the 97 maxima is a sound mechanical car... also what should i have the dealer change at 60 000km? thnx again...
Old May 22, 2001 | 08:19 PM
Ravq's Avatar
Re: thnx but...
I had a recall on my 96 for some O2 sensors but not sure if it applies to the 97's.
Old May 22, 2001 | 08:31 PM
Weasel's Avatar
There are no recalls on the 97 Maxima. There are TSB's though, but that doesn't mean your car will have the problem.
Old May 23, 2001 | 02:18 AM
vmok's Avatar
i think the '97 were pretty good in general and if something is/does go wrong, it'd be an isolated case and not something widely known... haven't had any problems with my '97 SE 5sp with 131,000+ miles...
just noticed i have a leak in the transmission neutral/reverse switch area and the a/c doesn't blow as cold as i like, but that's it for me... oh, and a front oxygen sensor... but these are supposed to be changed some cars around 100k anyway...
-V
Old May 23, 2001 | 06:57 PM
Difference?
Whats the difference between a GLE and an SE? which one is better and which is the higher model... the only difference i see is the rims.. someone plz enlighten me!
Old May 23, 2001 | 07:17 PM
Ravq's Avatar
Re: Difference?
I know that the SE has a tighter suspension (polyurethane bushings and that sort of thing) and usually comes with the 16inch wheels. The SE also comes with the painted door handles and window trim.
Old May 24, 2001 | 12:50 PM
vmok's Avatar
Re: Difference?
GXE is base, SE is the 'sport' model, GLE is the top of the line...
Depending on year, the only real factory options for the GLE were heated seats and ABS brakes.
The SE could actually be optioned up to the same level at the GLE and end up costing more. It had the 16" wheels, slightly firmer springs (i think like 50lbs more per side at the front), white faced gauges, body colored door handles, window trim, and grill, and a rear spoiler.
The SE with the auto and GLE had the electronically controlled hydraulic engine mount, whereas the electronicalliy controlled engine mount on the GXE wasn't available. The SE and GXE had black or interior trim pieces matching the trim, whereas, the GLE had the faux wood trim. The Bose sound systemm, sunroof, automatic climate control system, leather, and automatic transmission were standard on the GLE, but optional on the SE. That's all I could think of for now...
-V
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
maxinout93
Oct 27, 2015 01:29 PM
twotonezed
Aug 16, 2015 11:41 AM
