I need some help with technical issues...ecu 0304...and others
I checked my engine light code and I got 0304, knock sensor. What do I have to do and what kind of problems can this cause? Since yesterday my car has started shaking occassionally under any kind of acceleration. It shakes as if it is running out of gas, if anybody knows what i'm talking about. But there's plenty of gas. I wonder if my tranny is locking up on me??? Help
DTC 0304
This malfunction is detected when an excessively high or low voltage from the KS is entered to the ECM. Possible causes include...
- the harness or connector (The KS circuit is open or shorted).
- the KS
The KS may be checked with an ohmmeter.
1) Raise the hood. View the engine from the driver's fender. Look into
the deep valley between the cylinder banks and below the intake manifold.
Identify the KS as a black item fastened to the block by a single vertical
bolt. A wire harness wrapped in black leads toward you, out of the valley.
That is the KS sub-harness.
2) Follow the KS sub-harness to it's nearest connector. This is connector F121.
It is located near the upper right-hand corner of the valve cover of the forward cylinder bank, as viewed from the front of the car.
3) Disconnect F121. You have to do a "press the latch and wiggle and
pull" to disconnect it. F121 has only two pins; if you see more than two
pins, you have the wrong connector. Use a digital ohmmeter capable of
measuring more than 10 Megohms. You want to measure the pins of F121, not
the sockets of the matching connector. Measure the resistance between a
good ground (such as the battery negative terminal) and pin #2 of connector
F121. On my car this is the highest of the two pins, the one closest to
the front of the car. The factory spec is 500 - 620 Kohms.
The manual says you have to remove the intake manifold to replace the KS. However, I think that a person with good dexterity and a 10mm ratcheting box wrench could replace the KS without disturbing the manifold.
Tranny is probably okay
Shaking under acceleration could be caused by a misfire in one cylinder. This could be the result of a bad ...
- fuel injector
- ignition coil
- spark plug
Knock sensor, I felt your pain
I'm the master of the 0304 knock sensor code. That K.S. costed me $160 from the dealer. Get it changed as soon as you can. My O2 sensor went bad because the K.S. retardes the timing and makes the car run rich. So in other word it tells the ECU do dump more gas. This causes TTTTEEEEERRRRRIIIIBBBBBLLLLEEEE gas milage, and the performance will be lacking. Thanks Danny B. for the help.
My mechanic didn't have to take off the intake man. either. No trouble with it ever since, by the grace of GOD.
Holla!
Maxi-milliyon
Holla!
Maxi-milliyon
KS and rich mixture
Originally posted by maxi-milliyon
... My O2 sensor went bad because the K.S. retardes the timing and makes the car run rich. So in other word it tells the ECU do dump more gas. ...
I only use 93 octane, the best for the best. I can't check out my car today cuz it's raining like a hurrican e down here. I'll check that out asap. but where do i get an ohmmeter. I reset my ecu yesterday when i checked the code, and the light hasn't come back on yet. I only drove for like 20 minutes today.
I just drove some more and the last wasnt come on yet. My car is starting to shake even when I'm sitting at a red light...WHAT DO I DO???
Sound test...
This test is performed with the engine idling. Use a mechanic's
stethoscope or a length of rubber vacuum hose, and listen to each injector.
All injectors should sound alike. If you find one which makes a different
sound (or no sound at all) you have found a problem.
Resistance test...
This test is performed with the engine off. Use an ohmmeter to measure the
resistance of each injector. This does not require removing the injectors.
I don't know the correct resistance value for the injectors on your model,
but they are typically a low number such as 16 ohms. The important thing
is they should all be equal. If you find one injector with substantially
higher resistance than the others, it is bad. If you find one with zero
ohms (short circuit) that is truly unfortunate, because the injector is bad
and it may also have damaged the Engine Control Module (the computer)
because of excessive current drain.
Measuring the resistance of the front bank of cylinders is easy because the
injectors are in plain view. Disconnect the injector electrical connector
for cylinder #2, measure the resistance, reconnect the connector. Repeat
for the cylinders #4 and #6.
Measuring the resistance of the rear bank of cylinders is almost as easy,
but it is difficult to reach the injectors. The resistance may be measured
at a conveniently located electrical connector. Notice the largest,
thickest electrical harness at the top of the engine. This is the Engine
Control Harness and it is shaped like a U, with the open top of the U at the
driver's side of the car. The U has two corners. Look at the corner
nearest the passenger seat. Just inside that corner you will find an 8-pin
electrical connector. This is connector F131. Disconnect this
connector. Now look at the male part, the connector half with the pins
exposed. They are arranged in two rows of four pins.
The pins are numbered 1 - 4 (top row) and 5 - 8 (bottom row).
Measure the resistance of:
- injector #1 between pins 1 and 2.
- injector #3 between pins 1 and 6.
- injector #5 between pins 1 and 5.
Be sure to measure the PINS, not the female receptacles.
The dealer's shop is equipped with high-tech diagnostic instruments. These are wonderful devices but they are expensive and the dealer has to recover his cost by charging you for diagnostic time. Sometimes the home mechanic can do legitimate diagnostic work with nothing more than a ohmmeter and a rubber tube.
Originally posted by Daniel B. Martin
Sound test...
Sound test...
Where are my injectors??
Ask around your town. Ask friends, neighbors, coworkers. Chances are you will hear some horror stories, and also some glowing recommendations.
Independents usually charge less than the dealer. Perhaps you will find a former Nissan dealer technician who opened his own repair shop. That's a good man to know!
Please don't read this as a smartass answer because it isn't meant that way. If you don't know where your fuel injectors are, then you shouldn't attempt your own diagnosis and repair. Please seek a professional service provider.
I might be able to do it if i know where they are. I won't try it if i can't tho. Can you tell me where they are?
Please get a Haynes repair manual. You can buy this book at any large bookstore or auto parts store. It may be available at your public library. Refer to Haynes, page 4-9. It has a detailed explanation and good photos.
Re: Knock sensor, I felt your pain
Holla!
Maxi-milliyon
Holla!
Maxi-milliyon
Reason is i have a KS code but following Daniel B. Martin's instructions i measured a resistance from the KS that was correct. This is why i have not changed it. Althought at this point i think i am just going to change it and see what happens.
Ant
Re: K. S.
... Please explain how someone has giving me wrong info. ...
... the K.S. retardes the timing ... True.
... and makes the car run rich. False.
Maxi-millyon
Sorry for the repost but i need this info
Maxi-millyon:
Question: did you check the KS before you replaced it? By this i mean did you or your mechanic check the resistance reading of the KS to check if it is in spec ?
Reason is i have a KS code but following Daniel B. Martin's instructions i measured a resistance from the KS that was correct. This is why i have not changed it. Although at this point i think i am just going to change it and see what happens.
Ant
Maxi-millyon:
Ant
Knock Sensor test
Originally posted by Ant95se
... i have a KS code but following Daniel B. Martin's instructions i measured a resistance from the KS that was correct. ...
DTC 0104
i got some new info
my check engine light finally came back on
0104...0304...0504
what now?
i got some new info
0104...0304...0504
what now?
The Vehicle Speed Sensor installed on the transaxle. The part inside the transaxle has a plastic gear which is driven by the internal parts of the transaxle. The part outside is a signal generator which produces a square wave of amplitude 5.2 volts and frequency proportional to vehicle speed.
Remove the VSS, attach a voltmeter to the electric leads, and spin the gear
by hand. If you get zero volts, it's dead.
One owner discovered his VSS was not fully seated in the transaxle. He just tapped it inward, and retightened the 10mm mounting bolt.
For more information please refer to the Chilton repair manual (page 4-22) or the Haynes repair manual (page 6-16).
DTC 0304
i got some new info
0104...0304...0504
what now?
i got some new info
0104...0304...0504
what now?
- the KS
DTC 0504
i got some new info
0104...0304...0504
what now?
i got some new info
0104...0304...0504
what now?
This malfunction is detected when the ECM continuously receives an incorrect voltage from the TCM. Possible causes include...
- Harness or connectors (The communications line circuit between the ECM and the TCM is open or shorted.)
- TCM
- Discharged or faulty battery
0104
Vehicle Speed Sensor:
My speedometer has not been working for about 2 weeks and I could've figure out why. I'm planning on installing indiglo gauges next week when I receive them...do you know if it will work after I do this? What caused the problem?
... My speedometer has not been working for about 2 weeks and I could've figure out why. ...
... I'm planning on installing indiglo gauges next week when I receive them...do you know if it will work after I do this? ...
... What caused the problem?
Does the odometer work normally? If the Vehicle Speed Sensor is bad, it should not.
K.S.
Ant 95, My car gave off a code. I then had my mechanic check the harness with the meter. Then he check the K.S. itself and it was dead. He then changed and no problems ever since (by the grace of GOD). It also save me a lot of money in gas. Holla
Maxi-milliyon
Maxi-milliyon
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
