Cheap torque wrench!!!
Old May 29, 2001 | 12:53 AM
seanqlee
Where can i get thems? I went to homedepot and they had like $50-60 torque wrenches... I just need it for my FSTB (30lbs), and I wont be using it again.. I saw one Twrench for like 10bucks, but that had needles and the homedepot guy said that was really inaccurate. Someone help me if you know a cheap good place! (p.s. kragen or pepboys didn't have one.. they had that 10dollar cheap Twrench..)
Old May 29, 2001 | 07:15 AM
ajaffee
You can get the beam-type torque wrench from sears for about $25. It's accurate enough. The only drawback in comparison to the click-type torque wrench is that you have to be able to see the torque reading while you're tightening the nut. With the click-type, you just listen for the click.
For the FSTB, the beam-type is just fine. I suggest you use it for tightening your lugnuts too.
Old May 29, 2001 | 08:13 AM
Daniel B. Martin's Avatar
The best ones cost more than $200 but you can buy Chinese-made torque wrenches for much less. Look at http://www.harborfreight.com/cpi/ta...?itemnumber=239 This is a "click type" torque wrench, not a "needle type". I have used one of these for two years and am entirely satisfied with it. $20 + S/H is a good deal. Harbor Freight has had this item on sale at least twice in recent months for only $10 + S/H. I have used one of these "cheapies" for two years and am entirely satisfied with it.
Harbor Freight waives shipping (but not handling) charges for orders larger than $50. Perhaps you and your buddies can put together a shared order to save on shipping.
Old May 29, 2001 | 09:20 AM
seanqlee
thanks for the info guys
Old May 29, 2001 | 10:24 AM
clee130's Avatar
If you are planning on using the torque wrench just one time, you might want to also consider renting it. Go to your local PepBoys/AutoZone/auto parts store. Most of them should have a rent-a-tool program. Put down a deposit, use the tool, return and get your deposit back.
Old May 29, 2001 | 11:10 AM
SillePimp's Avatar
Got mine at Autozone for less than $30. It's the one that clicks and has a 1/2" driver. Just make sure to buy a 1/2" to 3/8" drive converter.
Pnjboyzz
Oct 7, 2015 10:47 PM
londonflu
40
Sep 25, 2015 09:11 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
pears
Sep 18, 2015 05:25 AM
