Car wont start, wtf is going on?
I had the car running, pulled into mcdonalds, turned the car off. pretty normal, then get back in, try to start it up, starts to crank slowly and dies. After that, all i get is a click everytime i try to crank it up. What is going on here? Jumping the battery didnt work. Checked my fuses and they were good.
maybe your starter is shorted...my friends civic had the almost same problem, the starter ground wire somehow wasnt screwed right on to the actual ground terminal, so it would sometimes start and sometimes die and not even start with a jump...
I say battery. Get it tested at Advance Auto or similar. Similar thing happened to me years ago in my Hardbody truck, except I had stopped at Hardees for lunch. Had absolutley no forewarning or anything. It wouldn't turn at all and it couldn't be bump started. Was tough enough jumping it off.
: your starter a few times ... But since you stated it cranked slowly then dies, sounds battery related. How about interior lights, are tehy working .. etc?
Check and clean all ground points.
same thing happened to me...first i thought it was the battery and had that replaced but then the car died again, and all i get is a little click, click sound
it's the starter...$150 plus core exchange at autozone.....make sure u count the teeth on the starter, mine's had 10...napa had a starter but it had 11 teeth....not sure if that makes a different but i went with the 10
I get a single click. it's the starter, my battery checked out at AZ. towed it with my dads 4runner to my house, and there it will sit til i feel like replacing the starter. im just fed up with my car lately, and this isnt helping its case
I had same problem, went to shocks and said either the battery or the ground wires is not ok. went to other shop and found out the battery died lasted me since 1997 till 2004. I went to car audio shop and picked Optima battery for about $180, becuse i want to run car system in my max. vooommm.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
