Temp gauge on the fritz
Old Aug 9, 2005 | 12:38 PM
tyrotrader's Avatar
My temp gauge goes to H (overheat) somewhat erratically and I do not suspect any real overheating problem. I've heard of this as a common 3rd gen Maxima problem.
Anyone know if this is a common problem? Fix??
Thanks,
Scott
Old Aug 10, 2005 | 06:51 AM
tyrotrader's Avatar
bump
Need a little help. Anyone????
Old Aug 10, 2005 | 09:25 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
could be the gauge itself or the ECTS is bad
Old Aug 10, 2005 | 11:52 AM
tyrotrader's Avatar
I just changed the gauge cluster, and is exhibiting the same behavior so I don't think its the gauge. Also, at time it moves irratically up and down - suspect some kind of sensor?
Old Aug 10, 2005 | 01:19 PM
killerVQ30DE's Avatar
Close but not quite. . the ECTS supplies temp readings to the ECU.. the sensor right next to it is the sensor for the temperature gauge
Old Aug 10, 2005 | 08:31 PM
ryant35's Avatar
Thanks,
Scott
My gauge was doing that, so replaced the sensors & it didn't help. It turned out that it was actually overheating, but it didn't feel like it under the hood.
My problem was caused by a wornout water pump seal, it was causeing an air bubble, and as the bubble moved it cause the temp to move up & down.
$598 later I had a new water pump and the problem was solved.
Old Aug 11, 2005 | 03:57 PM
tyrotrader's Avatar
Thanks,
I'll get it checked
I figured that since goes up and down quickly that it couldn't be real - but better safe than toast.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
