Need torque specs for suspension bolts, whoever answers is my hero.
Ok, im finally tired of all the creaking from my suspension bolts. i need torque specs for the whole goshdarn thing...
-3 front and 2 rear upper strut mount bolts
-2 front and 1 rear lower strut bolt
-1 bolt that holds the spring perch onto the strut shaft front and back
-4 bolts that hold the brake calipers on in front
whoever gives me these answers is my hero... im breaking down and buying a torque wrench tomorrow to rid myself of the incessant creaking once and for all.
Rain on your parade
- 3 front upper strut mount bolts: 29-40
- 2 rear upper strut mount bolts: 12-16
- 2 front strut bolts: 103-117
- 1 rear lower strut bolt: 80-94
- 1 bolt that holds the spring perch onto the strut shaft (front): 43-65
- 1 bolt that holds the spring perch onto the strut shaft (rear): 13-17
- 4 bolts that hold the brake calipers on in front: caliper pin bolts 16-23; torque member fixing bolts 53-72
I'm glad you will buy a torque wrench. It is a useful tool.
Don't be surprised if you check the torque on all these fasteners, discover them to be adequately tight, and find that the unwanted creaking sounds are still there.
Re: Rain on your parade
Good morning Daniel,
Since you are talking about the torque numbers, I would like to ask you one thing .... What is the specs number for the wheels lug nuts? Any answer will greatly appreciated. Warm Regards.
Thai Hoang.
Thai Hoang.
Originally posted by Daniel B. Martin
All torque values in this post are in foot-pounds.
Wheel nut torque
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
maxima-junky
Oct 7, 2015 06:13 PM
