Upper Intake Manifold Gasket
Old Aug 10, 2005 | 01:28 PM
Sounbwoy's Avatar
I knew I was forgetting something. After seeing the thread with the shiny valve cover, I need to find out if replacing the intake manifold gasket is pretty straightforward job to do. I have those dirt/oil stains right at the gasket and the car does have 230,000 on it. I'll be checking the Chilton's later, but any other advice would be great. Looke din stickies and google searched-nogo.
Old Aug 10, 2005 | 01:30 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
just take the UIM off. Replace gasket. Put the UIM back on. Its fairly straight forward. Nothing to hard to do.
Old Aug 10, 2005 | 01:46 PM
Loe max's Avatar
You might have to remove some things mounted onto the IM, but otherwise, its straight foward and maybe time consuming. The IM isn't light by any means, so don't be alarmed if you cant remove it it on the first try, just wiggle it alittle bit and you should be able to break the seal. The Bolts that hold it down are IIRC either 10 or 12mm.
Old Aug 10, 2005 | 01:47 PM
Sounbwoy's Avatar
Thanks, y'all
Old Aug 10, 2005 | 02:12 PM
Dman832's Avatar
You might not even have to take the USIM all the way off. When I put on the MEVI, I screwed up the gasket, so I got a new one, and took off the front bolts, and just loosened the back ones (2 I think), and slid the old gasket out and the new one in. Just make sure it stays in the right place when you torque the manifold back down.
Old Aug 10, 2005 | 02:15 PM
njmodi's Avatar
Do I get a tax break?
Thats the truth, except you'll probably have to loosen the EGR guide tube as well.
Old Aug 10, 2005 | 03:03 PM
scrhale's Avatar
Screw that ... do 00VI. Might as well if you are ripping apart the upper.
Old Aug 10, 2005 | 07:43 PM
Sounbwoy's Avatar
ehh. gonna pass on that. call me a purist. I like what I got already.
Old Aug 11, 2005 | 12:53 PM
Dman832's Avatar
O yeah, the EGR guide tube...you gotta loosen that too...good call.
Old Aug 11, 2005 | 02:08 PM
scrhale's Avatar
LOL 00VI is as pure as it gets ... pure kick @$$.
Old Aug 11, 2005 | 11:34 PM
86maxima96's Avatar
I Broke OT
do you have to worry about anything falling into the valves while the cover is off??
Old Aug 12, 2005 | 06:19 AM
Sounbwoy's Avatar
LOL. I hear you. Ultimately tho, this car will become a track (road course) only car with the possibility of racing as well as track events. Upgrades like that would make the car either illegal or classed against cars that are pure race cars. No fun there. Be interesting to research tho. Is there any info in stickies or threads on this?
Old Aug 12, 2005 | 06:35 AM
Seximus Maximus's Avatar
All Motor Forum
Old Aug 12, 2005 | 09:06 AM
scrhale's Avatar
A retrofitted manifold ... oh please. There is such a small community of Maximas in racing compared to the rest that they probably couldn't tell you that your 5 inch exhaust is aftermarket. But to the techincal part ... why does it place it in a different class because you have a different IM? Or would they dyno your car and see the numbers/graph???
Old Aug 12, 2005 | 12:43 PM
Sounbwoy's Avatar
Most regulated road racing classes will limit things that can be done depending on the classification of the car or where you want to run it. The SCCA is the big dog and MOST racing regulating bodies model their rule books after the SCCA rulebook. So, to your points.
How many factory cars do YOU see with 5" exhaust? And no, mine is not 5" either.
Secondly, if you install a part that is seen or known to provide an ADVANTAGE in HP, and that part IS NOT APPROVED in the rulebook, the car will be illegal or other drivers that are familiar with the car can file an official protest and get the engine torn down, AT YOUR EXPENSE. This ain't no run what you brung stuff.
There is cheating in racing, no doubt, but I don't have the time or the $$$ to get stuff torn down, especially if somehow I was able to walk down and pass cars that I shouldn't be passing.
It's also just not worth the time or effort to me either. My car is plenty fast enuff by it's own self....
Without getting too far in b4 I get flamed and redirected to the Racing Forum, in IT (Improved Touring), exhaust is free (open), brakes and suspension can be upgraded but STOCK parts must be used (no BBK), suspension points cannot be relocated. Engine can be blueprinted, mild port & polish, no big cams, intakes are allowed, and so on. If you have an SCCA club where you are go to a meeting and talk to 'em.
Old Aug 12, 2005 | 07:07 PM
scrhale's Avatar
Lol I was exagerating about 5 inch exhaust. I never knew about SCCA regulations. I am just thinking quarter mile fun .
Old Aug 12, 2005 | 08:06 PM
Sounbwoy's Avatar
You know, one day I'm gonna try that drag racing thing....There are several 1/8th mile tracks up here and Rockingham is only about a hour or so away....
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
JonBlz
Oct 5, 2015 06:02 PM
MichMaxFan
Sep 30, 2015 09:18 AM
dshinn
Sep 26, 2015 08:07 PM
