Whining sound at different speeds wtf
Old Aug 14, 2005 | 10:23 PM
talisman311's Avatar
This is driving me nuts:
@ 45MPH there's this loud humming noise coming from what sounds like the driver side front tire (that general area). go to 50 and it's gone. @ 60 it's back and then past 65 it's gone.. it's loud and sounds like how a cheap tire would hum on the highway.. anybody have any ideas?
Old Aug 14, 2005 | 11:43 PM
NY 95 VQ30DE's Avatar
Easy fix....
Dont drive over 45 mph. Then you wont hear it.
Old Aug 15, 2005 | 12:04 AM
1996blackmax's Avatar
It may be your wheel bearing going out.
Old Aug 15, 2005 | 04:28 AM
4thgenx42's Avatar
Wheel Bearing. A very common problem with our cars. It isnt that expensive you'll probable spend, $79.00 including the two grease seals...
Old Aug 15, 2005 | 05:51 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
or if you have a automatic trans sound like a planetary gear set is going.
Old Aug 15, 2005 | 11:38 AM
I thought it might be the wheel bearing, so I tried something I read on the forums..that is: make a sharp turn taking pressure off the suspected wheel bearing, if the sound stops then it probably isn't the wheel bearing. Not sure though.
Killcrap: that sounds expensive. Can you provide any more info? The transmission shifts fine so far and I have a B&M 26,000 GVW rated cooler.
Old Aug 15, 2005 | 06:50 PM
PRLWHTMAX's Avatar
I think I maybe having the same problem. My whining noise goes on an off at different speeds. First I thought it was some kind of rubber making a high pitch squeal but im begining to think if it was rubber it would have worn out by now or melted. Does your noise sound like a high pitch squeal? and does it get louder the faster you go and it softer and finally stops when you are at a complete stop? this noise is very irritating but i cant here it right now because its too hot over here to ride with the windows rolled down.
Old Aug 15, 2005 | 08:23 PM
I can hear it with the windows up, windows down will just drown out most of the noise. It's not a high pitched squeal, the only way I can describe the sound is that of a noisy tire. The sound is intermittent, from 37-42 MPH it whines with 40MPH being the loudest. 50MPH I can't hear anything and it comes back but not as loud @ 60MPH. I can't figure out what it is, and I've ruled out the possibility of it being a wheel bearing.
Old Aug 15, 2005 | 08:53 PM
If it is the wheel bearing and it is not changed in time it will start sounding crunchy. At that point the hub assembly may need to be replaced as well.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
