Wheel Spacers
Old Aug 16, 2005 | 04:59 AM
Peter Taylor's Avatar
Wheel Spacers
Other then the fact that depending on the size of the spacers you may have to install longer wheel studs, are there any real concerns with using wheel spacers on the max. For example.....I see that some people have hammered in the dust cap on the rear to help with new wheel fitment but why not just install wheel spacers ?
Peter Taylor
Old Aug 16, 2005 | 05:33 AM
Mizeree_X's Avatar
Getting back to his roots
Peter Taylor
Because hammering in the dust cap is free and buying spacers is not? Some people feel that if the wheel isn't mounted on the hub lip, that the wheel can become unstable and wobble. I personally feel that if you mount and torque the wheels down properly, you will be fine. I've been running spacers for two years and have never had a vibration problem.
Old Aug 16, 2005 | 01:42 PM
Nismo's Avatar
I also have had H&R spacers for years on my old wheels and had no problem with anything. Just buy quality hub centric spacers like H&R not those universal pepboys type.
Old Aug 18, 2005 | 09:34 AM
DUKEE's Avatar
Does the dustcap come off? I got new 18 wheels and the wheel caps wont fit on the rear, as well on the front. I am getting wheel spaces for front and rear. However there are dust caps on the rear that will have to come off so i can fit my wheel caps. Do they come off? Is there a solution? I got pics here -> http://www.cardomain.com/ride/2087456
Old Aug 18, 2005 | 09:37 AM
Wheel Spacers
Not sure if they come off or not ? Sounds like most people just pound in the dust caps. Depending on the wheel might look better with spacers anyway.
Peter T
Old Aug 18, 2005 | 09:47 AM
DUKEE's Avatar
Pound in eh? So u cant take it off with hammer i guess and flathead? Anyone got pics of what it looks like hammered in?
Old Aug 24, 2005 | 06:41 PM
Supermax95's Avatar
exactly flasthead with hammer. Pound the flathead into them(make a whole) and pry them out.
Old Aug 25, 2005 | 10:01 AM
1FSTMAX's Avatar
i've had 5mm spacers in the rear since may... My wheels wouldnt clear the hub, i tried smashing the dust cap, but the wheels still wouldnt fit. So i replace the smashed cap with a new one, got longer studs, and added a 5mm spacer. No problems so far.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
