how to remove grill emblem?
Old Aug 18, 2005 | 08:49 AM
sk24iam's Avatar
How do I go about removing the emblem from my grill? I cna't seem to get it off and I don't want to break it.
Old Aug 18, 2005 | 09:21 AM
mendon99's Avatar
tastey wheat
i am also curious, id like to paint it black.
Old Aug 18, 2005 | 09:22 AM
THEJEFFERATOR's Avatar
my 95 has 2 phillips head screws on the back side, not sure on 97?
Old Aug 18, 2005 | 09:40 AM
BlackCat's Avatar
RIP '98 Maxima SE
It looks to be pressed in. There's two plastic prongs showing on the inner side.
Old Aug 18, 2005 | 10:18 AM
sk24iam's Avatar
mine just has two pins going through pack but the emblem is on there good so I don't wannna just pry it off
Old Aug 18, 2005 | 10:24 AM
BlackCat's Avatar
RIP '98 Maxima SE
Sounds like its glued on? Have you tried pressing on the pins to push the emblem out?
Old Aug 18, 2005 | 10:34 AM
i called my boy at the body shop, the 2 plastic prongs are just guide pins. it's held on with urethane tape..strong **** !!! if your gonna take it off, you need to get some sort of double sided tape to put it back on cuz it wont come off "clean".
try to get behind the emblem with a razor blade or something (fishing line works, gotta saw through it) don't hafta get it all, just enough to loosen it up, then try to gently pry on it evenly, a little on each side at a time. should come off pretty easily.
probably easier to take out grill, tape it off and paint the emblem. ..looks great black !!!
Old Aug 18, 2005 | 11:54 AM
sk24iam's Avatar
ok, got mine off. wat a pain. what is the best thing to use to reattatch it to new grill?
Old Aug 18, 2005 | 11:57 AM
Iron Scimitar's Avatar
Tha Snatcher
glue....
Old Aug 18, 2005 | 12:53 PM
i would use a good quality, thick double sided tape, 3m or somethin. just put it on the "rectangular" part, dont worry about the "ring" heat the tape up good w/ a hairdryer for better adhesion. you could also put a couple small zip ties around those pins for extra protection.
Old Aug 18, 2005 | 07:30 PM
bhmax16's Avatar
If you know you'll never want to take it off again I'd JB weld the sucker back on...but...I'm also addicted to JB weld and use it just as much as ghetto people use duct tape
REDinLV
Aug 15, 2024 12:30 AM
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
ricky7780
Sep 24, 2015 06:50 PM
