Jerking.......
While i'm driving just regularly i feel a jerk every time it switches gears. It is kinda rough...Does that mean something is wrong with my trans. Do i need to replace it or whats up???
I'm guessing you have an auto like me, well, I had the same problemand what I did to solve that was a simple drain and refill. Now it feels a lot smoother. I also installed a tranny cooler to make sure it'll last longer.
Check your dropping resistor
Re: Check your dropping resistor
Originally posted by Daniel B. Martin
Check your dropping resistor. This component is mounted on the front side of the drivers-side strut tower. It has a gray plastic connector with two wires. This test is made with the ignition off. Disconnect the connector and use an ohmmeter to measure the resistance. It should be about 12 ohms.
Mine's always been 12 Kohms
Thank you for the correction
Originally posted by gtr_rider
how much did it cost to drain and refill the tranny.
It should only cost about 4-5 quarts of tranny fluid depending if your going with synthetic (costs a little more). I can't talk for the 5-spd, but I know its pretty easy to the DIY mechanic, just a simple removal of the drain plug. The tranny fluid should consist of 10 quarts, but a simple drain and refill will only drain about half of it. To get almost all of it, you can try the drain and refill about 3 times to make sure all of the older fluid is gone.
why would you only get 4-5 quarts if the tranny holds 10 quarts???
Please check your dropping resistor. This component is mounted on the front side of the drivers-side strut tower. It has a gray plastic connector with two wires. This test is made with the ignition off. Disconnect the connector and use an ohmmeter to measure the resistance. It should be about 12Kohms.
It's really easy to find. It sits right there on front of the strut tower mount, right next to the air filter housing.
If you check it, let me know your reading. I got 12.5 ohms, as per the FSM, not Kohms, like the earlier posters said. But someone bumped a 7 year old thread, and I don't think Daniel Martin has been around for some time, so I can't ask him...
