Clear Corner Fix!!!
last week i installed the clear corners i bought from benblanco, which were originally purchased from courtesy nissan. i was extremely satisfied with the look, but the fit was far from perfect. as i compared the original and the clears, i noticed that the nipples on the small pieces were metal, not rubber-coated (like the original). so, i unscrewed the original nipples, treaded holes of the new clears, removed the metal nipples, and replaced them with the originals. i fitted the new clears again, and noticed a slight improvement, but they were still loose. after comparing the new & original again, i saw that the ends of the back of the new clears were not as thick as the originals. i cut two one-inch pieces of 1/4-inch rubber hose, then cut each longways and put on the back ridges of the clears. after doing so on all four pieces, they fit perfectly. hope this helps to anyone who has the same problem!
Sup man, I'm glad you like them. I had the same problem with another set before they got stolen. They were just like those and I had to wrap some electrical tape around the tabs to make them fit snug. As for the metal tabs, I had to unscrew them a little so that they would fit deep into the plastic sockets. They were great until somebody snatched them off my car, including the bulbs. I got the Diamond Cut Lenses now, and I'm thinking of getting special screws of the same thread for a little security.
The anti-theft method of install on the new diamond cut clears doesn't work (at least for me). I don't know if the threads on the pegs that screw in are shorter than the ones on the old clears or what, but the screw was definetly not long enough to fit through from the other side along with the washer. If anyone knows the exact size of the screw required for replacement, let us know please. I have them on the easy way now and it would suck to have them stolen.
Originally posted by BenBlanco218
Yes please, someone let me know too. I'd kill someone who takes my new ones.
Originally posted by matty
I was gonna do the anti theft thingy with the sqrew but mine fit really good...thats what ya get for 70 bones...
Apr 16, 2020 05:15 AM
