SES light on after engine repair
I just repair the engine by doing a cylinder head and gasket change, along with cooling system. I had no light until I drove for about 30 minutes. Went to the mechanics and said the computer is reprogramming itself and will take a couple of days. Is this true?
Did you just do all that work yourself? If yes, then it surprises me that you are asking such a rudimentary question about the SES.
In any case, your mechanic needs a
Read the ECU howto sticky and retrieve all the stored codes in the ECU, that will help you figure out what troubles the ECU is reporting. Alternatively, go to Autozone, where they will retrieve the codes for you for free.
Out of curiosity, why did you need to replace the head gasket?
Cheers.
.Read the ECU howto sticky and retrieve all the stored codes in the ECU, that will help you figure out what troubles the ECU is reporting. Alternatively, go to Autozone, where they will retrieve the codes for you for free.
Cheers.
No, I did not do it all by myself. My mechanic did it. And yes, it was the entire cylinder head in the rear along with head gasket being replaced. I thought I seen posts that said the computer codes that trigger the SES light will be re-programmed somewhere from a day to a couple of days when the engine is disconnected for 3 weeks. Just want to confirm.
If you read the stickies at the top of the 4th Gen Forum, you'll find instructions on how to retrieve the error codes stored in the computer. That is why the light is set. It will not fix itself.
I'm not sure what to think of a mechanic that can replaces heads, but not retrieve ECU codes via an OBD-II scanner...
He did retrieve the ECU codes, but he said that it will re-program itself since it has been disconnected for weeks. It was giving codes one by one, and then clearing some of it one by one, but not all yet. Just seeing if anyone experience this before. I read from some inspection posts saying that it 'does' go away in a couple of days. If no one experiences this, I have to go to find out the problem. Thanks for replying.
Check your codes.
Check your codes.
You never answered the question, why did you need to replace the head?
Check your codes.
Check your codes.
Your theory on 4th gen ECU/diagnostic/reset/ etc is pretty skewed ... If something is wrong, the light will trip, even if not lit, there may be codes stored, check them very soon to see
codes are stored.
Check your codes.
Check your codes.
It wont go away, only to return, you have to fix the problem in order for it to go away.
Did I mention you should check your codes?
Check your codes.
Check your codes.
Check your codes.
codes are stored.Check your codes.
Check your codes.
Originally Posted by NmexMAX
Check your codes.
Check your codes.
Check your codes.
Check your codes.
codes are stored.
Check your codes.
Check your codes.
Check your codes.
Check your codes.
Check your codes.
Check your codes.
You're a bit vague in your posts ..My point is, you need to help us help you.
Provide details of the vehicles history .. one important note.. why is there a hole in your head?
This may or may not have vital information that may help better diagnose your problem... Did your mechanic tell you it had a hole or did you see it?
FYI .. My heads have A LOT of holes in them
Sorry for the vague posts. Okay, let me start off with the history:
This Maxima had a lot of problem initially. First off, it was burning oil badly, about 2 quarts per 500 miles. There was like huge blue smoke from the exhaust everytime I accelerate. So I ask to fix that problem. He bought a set of gaskets and screws and took off the 2 valve covers on the engine. He also gave it a coolant flush along with new hoses and radiator cap. He discovered another problem and asked me if I want to fix it. So I bought the used cylinder head and he installed it for me. Now everything was fine after 3 weeks. No more burning oil. I even test drove with him for 45 minutes. The next day, I tried driving it again, in about 5 minutes in a turn, the SES light came up. So I went to him and he put in the OBD-II scanner to check for codes, it came up with 3 codes, and then 2, then 1, then none after the turning the engine on. He told me that if it happens again, it should clear away in a couple of days. And I remember a couple of people on Maxima.org had their SES light cleared away after an installation of 'something'.
Good things that happened:
Feel an increase in HP when acceleration
No more burning engine oil
Bad things that happened:
SES light
White smoke once in the first 500 miles (burning coolant?)
So I checked the coolant, was at the MIN line.
Nothing else that I am worried about. Inspection is in another month, that's why I posed the question. Guess now I have to fix these problem first.
Thanks for reading.
SES light
Thanks for reading.
White smoke and low coolant indicates you are burning coolant ... which means your head gasket is leaking, which means you are going to warp the head, which means... you get the idea... or no?
The codes remain there until you delete them or the ECU see's your enigne run correctly from a cold start up to full hot several (50?) times.
They don't dissapear as you read them and run the enigne.
If I were you, I'd be looking for another mechanic to work on the car.
The head gasket problem again? Someone quote me a price.
If you have your car there with you, and have 15 extra minutes with a flat screwdriver, check
the codes .. now..
He discovered another problem and asked me if I want to fix it. So I bought the used cylinder head and he installed it for me...
Pull The Codes
If you are having those kind of problems on a '99 it must have been BEAT before you bought it. It takes 5 mins to check the codes. Do it now or just keep paying this idiot to tell you that the light does magical blinks and resets itself.
PULL YOUR CODES
and go somewhere else to get the work done . . .
PULL YOUR CODES
This thread is hilarious
The mechanic has screwed you, and if your still having most of the same problems, I would look into finding another engine and see if some people around you can help with the install for a decent price.
I'm not talking about the head problem here. It's only about the CEL after the repairs. This mechanic doesn't seem to fix most of my problems. Changing to another mechanic. Wasted enough money for a new engine. Thanks all.
man how much did you pay for your mechanic to install this ? How many miles on your engine ? I had a leak in the timing cover got a engine with 40k on it from a junkyard. I paid 350$ for the engineSwapped it in everything solved not one problem! Not even a cel. Even the coil packs they gave me were good!
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
