knock on startup
knock on startup
i'm not sure if n e one has had the same problem but i have a strange knock rite at startup, for about 1-1.5 sec and then goes away and no problems i rn mobile 1 and mobile 1 oil filter change the oil atleast every 3000 if not more and just wondering wtf
i was also reading the hard starting problems some of you guys were having and i noticed if my car does'nt start right away if i turn the key off and let it set bout 5-10 sec it usually starts right up and no problem, sure its not the solution, being the tranny swap's and all just putting my 2 n
thanx
thanx
That noise is your timing chain tensioner, the chain rattles before it gets oil pressure and takes the slack out of the chain. Quite normal as cars get up there in mileage. 2 of my 3 maximas have done it.
my odo is 235,000kms
Originally Posted by killerVQ30DE
I get this too, would this trigger an 0304 code? I don't think it does but thought I check
Originally Posted by 99I30lmtd
appreciate it guys nothin i can do besides replace the chain and the tensioner????
thanx again
thanx again
Originally Posted by njmodi
If you are getting a startup rattle from the timing chain cover area, then its the tensioner. That rattle will not cause the KS code
DC_Juggernaut
Sep 28, 2015 04:07 PM
