Help I'm Really Worried About This Noise!!!!
Old Sep 8, 2005 | 10:10 AM
Dexter's Avatar
My MAX has a rattling noise, so I figure it's the guide tensioner but with all the talk about the new guide tensioners not fitting through the access panel i've been trying to find out if an aftermarket guide tensioner would fit through it so I could change it myself to no luck, but when I turned on my car this afternoon it had a REALLY loud rattle noise followed by SCREECHING sounds! sounds like the chain is grinding on something. Is it past replacing the guide tensioner now, and would I need to consult a professional mechanic to get the problem fixed? If so where could I take it, because I can't afford the estimated 800 dollars quoted for changing the tensioner at the dealership. Is there anyplace where I could take it where I could set up somesort of payment plan or something?
-Dexter
Old Sep 8, 2005 | 01:39 PM
Dexter's Avatar
I called the dealership and they told me that the rattle could be caused by the guide (not guide tensioner), and they say that what Nissan advises is to pull out the plastic guide and leave it without one (i forgot the word he used, it starts with an A). I'm no professional mechanic but does this sound like a logical solution to anyone?!
Dexter
Old Sep 8, 2005 | 01:45 PM
njmodi's Avatar
Do I get a tax break?
Screeching is probably just the belts...
Old Sep 8, 2005 | 03:41 PM
Dexter's Avatar
My first thought was that but it sounds like metal grinding, I've been unwillingly putting off the tensioner (can't find 1 that fits through the panel ) thing for 3 weeks now and I'm starting to fear the worse
-Dexter
Old Sep 8, 2005 | 05:25 PM
Dexter's Avatar
i'm gonna change the belts to see if it's that.
-Dexter
Old Sep 8, 2005 | 06:31 PM
njmodi's Avatar
You can also just get some belt dressing and see if that cures the problem temporarily.
Old Sep 9, 2005 | 04:14 AM
Dexter's Avatar
yeah but I'd forget to change it if I do.
Old Sep 9, 2005 | 04:50 AM
4thgenx42's Avatar
What is a guide tensioner? I know that my car has a screeching sound, but that happens because my belt tensioner is bad...
Old Sep 9, 2005 | 05:26 AM
PAREDLINE's Avatar
I have the same rattling sound. Its the tensioner thats on top of the motor in front. Its a bolt that you can access very easily from the top. I think it tensions the AC Compressor and the Alternator belt.
Old Sep 9, 2005 | 06:52 AM
njmodi's Avatar
The rattle is probably the timing chain - which will not be fixed by adjusting the tensioner you are talking about... or maybe I misunderstood ... if the belt is screeching, tightening it using the tensioner adjustment for the idler pulley may solve the problem (if the screeching is because of a loose rather than worn belt).
Old Sep 9, 2005 | 07:50 AM
Dexter's Avatar
so is it impossible for the screeching to be coming from the timing chain?
-Dexter
Old Sep 9, 2005 | 10:11 AM
PAREDLINE's Avatar
The timing belt wouldnt screech because we dont have a timing belt!
I think he's talking about the accessory belt. The alternator - compressor belt. I might be wrong. But this belt tensioner rattles when I hit the gas on my car.
Old Sep 9, 2005 | 11:21 AM
njmodi's Avatar
Ok we are on the same page... Your rattling comment was on the tensioner rattling... I've never heard of that happening... the only rattles I've heard (metallic), in that area of the engine bay, are from the timing chain itself. The timing chain rattle is from a bad timing chain tensioner.
The screech, as I had suggested originally, is probably just a loose accessory belt.
Old Sep 9, 2005 | 03:55 PM
Dexter's Avatar
ok but is the screeching coming from the belts of from the chain? since I they're too close together to tell where it comes from.
-Dexter
Old Sep 12, 2005 | 10:28 AM
Dexter's Avatar
-Dexter
changed belts screech is still there i'm taking it to a mechanic :'(
-Dex
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
