If I went back to stock manifold, would I still need a tune as badly?
Hey yall,
I drive a 98 5-speed with JWT ECU, MEVI, Y & B pipes, UDP and intake and I was wondering if getting a SAFC-II would be as necessary if I switched back to the USIM manifold.
Bruce
Bruce
sweet. Hey Zach I dynoed tonight. I'll try to send you the files. The JWT ECU gave me 6 WHP and 11 WTQ. There is something really wrong with my car though. We had to open the MEVI manually and my #'s were STILL way off! I'd like to hear your comments on them.
I can send my scanned Dyno to whoever can post it. My #'s are at LEAST 15WHP and 10WTQ low with the VI being manually opened. I'm not even going to post the Dynos where the VI didn't open because they are very close to stock #'s.
Something is messed up on my car.
I can host the pics. send them to Mdeezy@gmail.com
zackmax99@yahoo.com. i can compare your run files to mine and post them if you like
his dyno run - *resized*
link to the full size version
http://img.photobucket.com/albums/v7...Pics/Dyno2.jpg
Originally Posted by 96sleeper
Have you checked knock sensor, plugs, coil packs, misc. maintenance items? Your A/F ratio should not be causing that much power loss.
My Knock Sensor was changed right before I bought this car. (50k ago) and I'm not getting a code for it either. Shoot, I don't know what else to check for...
On my dyno:
The top line is with JWT ECU and the bottom is with Stock ECU. Bijan manually opened the MEVI on both runs.
once you get the run files send them to me i would like to compare them to mine to help you figure out why your car is down about 20whp and 15wtq
I just sent an email to the DynoLab. I know my power is down because before the MEVI and JWT ECU I pulled 178.5 WHP and 190.5 WTQ!!
Anyone care to speculate what is going on with my car???
Another thing no one has mention and it maybe a long shot but i noticed you are in atlanta what octane gas do you think your getting? With all this hurricane stuff and gas crisis maybe the stuff they are give you guys is garbage
Bruce, dont feel bad, we'll figure this mother out, and make it more powerful.
This video is to serve the purpose of comparison of USIM and my mods vs. his and what problems he may have. See for yourself...
http://www.v6atlanta.com/bijan/iwalkbruce.wmv
Post what you think
Post what you think
Is this the same dyno as you have made your other dyno runs on?
That is the same dyno that I have gone to every time, it seems to work fine for me.
Do you have an air leak around the manifold? gasket installed incorrectly, blocking the path of the air? It could be tons of things. Does the car drive and run perfectly normal under all other conditions?
Just replaced the MEVI gaskets 2 months ago. I had JAY25 help me with it. Somedays it runs ALOT better than others I mean there is like a night and day difference sometimes.
I haven't done a compression test but I figured since I put a low mileage motor in last year that it should be ok? I will definately look into it though.
Post what you think
Post what you think
humm i hope mine is working. ill have to make a video. i mean it opens and all but it doesnt feel much different. Check the hose that goes to the EGR valve. my strut bar rubbed it and ripped it a little. its taped with electrical tape now. maybe i should fix that.
sonic7
Aug 20, 2015 12:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
