Fuel pressure tester recommendation
Is there any particular fuel pressure tester (brand and model number) that anyone can recommend me?
I'm just looking to add one to my toolkit and want something that will work across a variety of makes and models (including my 4th Gen).
I have seen products from Equus and Actron (in addition to Snap-on)...
Thanks!
Thanks!
I wasn't sure how many times I would be using it so didn't go overboard. Got the Actron locally and it comes with some GM fitting. I cut that off and just bought some hose, clamps and a brass T-fitting. Worked great and I could definitely rule out the fuel line as being the problem in my ongoing hard starting situation. Definitely better than me swapping out the fuel pump... and then the FPR! Who know, I may use it again for future cars I work on, so you are right to want cross-platform use. If I wanted to use the GM fitting, I still could with a brass fitting with barbs on both ends.
Thanks...
Did you just insert the pressure tester inline (with the T) after the fuel filter?
Does our fuel rail have a test valve? (Schraeder or otherwise) ?
I see Equus makes a tester (model #3642) that is supposed to work with our cars, but their website is down right now, so I couldn't pull up their instruction manual to see how it works.
Originally Posted by Mishmosh
That's exactly what I did. I was told our cars have no port to test fuel line pressure.
Originally Posted by Jime
Buy a gauge and T for $10 and put it there and leave it. Mine has been sitting there for 2 years, cheaper and easier than buying a tester.
I might just do that.
jmlee44
Oct 2, 2022 02:13 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
