Trans Vin Number
Old Sep 13, 2005 | 12:52 PM
madmaxima420's Avatar
Trans Vin Number
I bought a 2001 5 speed A.E. trans and wanted to make sure it has the VLSD, is there anyway i could tell this through the vin, or by the trans itself without opening it up? thanks
Old Sep 13, 2005 | 12:54 PM
njmodi's Avatar
Do I get a tax break?
5th Gen'ers are more likely to be able to help....
Old Sep 13, 2005 | 01:07 PM
i tryed and after a long wait i was told to call nissan, so ill stick with my 4th gen family for now.
Old Sep 13, 2005 | 06:12 PM
killerVQ30DE's Avatar
Hey
These pics are from my 4th Gen LSD gearbox, should be the same for the 2001 AE
If you look in the axle holes the drivers side should have a 2nd set of splines, whereas a Non-LSD gearbox both axle holes will look like the passenger side with only 1 spline
Drivers side
Passenger side
Old Sep 13, 2005 | 08:19 PM
djengr's Avatar
I don't have my 96 max here, it is with my daughter at college. However I do rembember on that particular model there is an ID tag some where under the hood that will give engine code and trans code. On the trans code near the end of one of the sequence of numbers will be a letter A or V. V stands for viscous or limited slip. I don't know what the A stands for. Take a look under the hood see if you have that ID then call the nissan dealer to verify what the trans code means.
Old Sep 13, 2005 | 09:56 PM
aznsap's Avatar
ya there should be a tranny code stamped somewhere on the bellhousing, i think closer to the engine side. if it ends in a V it should be LSD, and if it's open diff it hink it ends in an A. just curious, how much did u pay for this tranny?
Old Sep 14, 2005 | 06:37 PM
i payed 1200 for the tranny and got a 95 motor for 350 55k on both
Old Sep 14, 2005 | 06:54 PM
Are you just trying to brag or do you want to know if its LSD?
<tap tap> Is this thing on <tap tap>
Check the pictures above, compare it with your transmisison
The A in the transmission code means it the open trans type, won't help you as the transmission is out of the car so no VIN plate.
I looked on my trans and I can't see any model numbers (trans is on my garage floor so I have had a good look)
Old Sep 15, 2005 | 07:17 AM
Zack342's Avatar
Probally just wants to brag but like stated above that is the best way to tell if it is a VLSD.
Old Sep 15, 2005 | 08:53 AM
MaximaSE96's Avatar
Maxima Owner
i am gonna be a **** today but its impossible for the tranny to have a VIN...it can have a TIN but not a VIN
Old Sep 15, 2005 | 01:07 PM
Picky Picky VIN plate is bolted to your firewall.. as well as having the VIN code for the car it also has the transmisison code on it
Old Sep 17, 2005 | 05:33 PM
i havent got a chance to look a the trans itself, because im not at my house for the time being, but i did write down what was on the small plate on the trans.
JN1CA31A9 and *T303*23
and there are two upsidedown T's where the *'s are
and im not braging im just proud
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Oct 4, 2015 08:43 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
