Fuel Induction System Cleaning
Old Sep 14, 2005 | 05:16 PM
XaMMax's Avatar
Is this worth the money? I am thinking about having it professionally done not just using the bottle of cleaner you pour into your gas tank.
Old Sep 14, 2005 | 05:31 PM
Gray305Max's Avatar
Opa-Locka Goon
I had mine professionally done and I could really tell the difference. The response was much better and all.
Old Sep 14, 2005 | 06:06 PM
Rowan's Avatar
Try spraying some carb cleaner into your intake, around your throttle body, etc. You'll probably notice a difference.
Old Sep 14, 2005 | 06:17 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I had a fuel induction system cleanup done on my max, very notable difference. worth the $$ IMO
Old Oct 16, 2008 | 08:12 AM
2themaximum's Avatar
I have a 2006 Maxima with about 53K miles and my car is with the dealer. They contacted me about having my fuel induction system cleaned. They said it was needed and would cost me about $225....is it really worth it and I am almost certain to get it done elsewhere at a fraction of the cost
Old Oct 16, 2008 | 10:23 AM
Scottwax's Avatar
That's Mr. Detail to you
Just be careful with a 2002 and newer. You mess with the throttle plate while the engine is off and you risk ruining your drive-by-wire throttle body.
I noticed a difference when I had it done to an Accord I used to have, car felt more responsive. Most lube shops do the service for around $60 or so.
Old Oct 18, 2008 | 06:18 AM
niagara22's Avatar
Fuel Induction Service
It is worth the money. I went to Nissan and paid $175 to have it done and I noticed some performance improvements. My car switches gears seamlessly, instead of it jerking before getting into gear. Second, the acceleration has improved.
Old Oct 22, 2008 | 12:29 PM
Edge's Avatar
If you go the do-it-yourself route make sure you use intake cleaner that is oxygen sensor safe or you could trash the o2 sensors. CRC makes this type of intake cleaner along with some others. The intake cleaner along with a bottle of Chevron Techron (make sure you use only Techron) might be a good way to see what results you get before you spend $100 - $200.
Old Nov 2, 2008 | 03:33 PM
fishforlife2007's Avatar
i heard valvoline if you have any in your area has a 3 part fuel system cleaning. i beleive its just under 70 bucks. might wana give that a try.
Old Nov 2, 2008 | 08:56 PM
gnar07's Avatar
is this the same thing as motor vaccing?
if so, i just got it done, seems to rob power and makes ur car smell funny for a few days, then its better than ever
Old Nov 3, 2008 | 07:59 AM
Drockb418's Avatar
Looks like I might be doing it soon
Old Nov 3, 2008 | 05:06 PM
nissandriver777's Avatar
i have had it done to our murano with the BG products offered at the local dealership...very big difference in response. plan on using the same service on my new max when it is due.
Old Nov 14, 2008 | 08:14 AM
Synki's Avatar
DIY. Get a can of sea-foam and run it through a vac. line.
Old Nov 14, 2008 | 08:57 AM
btvenom's Avatar
YES it is 100% worth it from personal experience, but do it yourself it's really easy
That's what I say, I used Seafoam, and CRC MAF Cleaner, and I noticed a huge difference, it wasn't the first time I've used Seafoam, but the first time my MAF was cleaned in 127k miles... VERY Noticable difference...
Old Nov 14, 2008 | 03:11 PM
pezfallout's Avatar
Worth it, just try to find a good shop and avoid the dealership. It will be way cheaper.
Old Nov 15, 2008 | 12:12 PM
302Xplorer's Avatar
Aside from spraying the throttle body with carb cleaner and scrubbing it, I have used Techron concentrate without any problems.
302X
Old Nov 17, 2008 | 10:56 AM
LUNATIC's Avatar
Dito ,use Techron twice a year , never needed the dealer cleaning service.
Old Nov 17, 2008 | 11:38 AM
Torgus's Avatar
rip off imo...
Old Feb 28, 2009 | 07:06 PM
foreeyed's Avatar
Can you haggle?
Can you haggle the price with some of these dealerships?
Old Mar 4, 2009 | 06:40 PM
maxed98's Avatar
Take a bottle of Sea Foam and with car running take off the hose that runs from brake booster to the intake and stick it in the can of sea foam and have some one inside the car to keep it running for a few secounds while it sucks some more out of the can and let it die. Let it sit for like 20 mins. and fire it up watch all your carbon blow out. Dump some in your tank when you fill up too. It smokes real bad but it will clean that bad boy out.
Old Apr 22, 2011 | 08:24 AM
BigLou55's Avatar
I know this this thread is quite dated but what they hey...I just had the BG fuel/air induction service done at a local shop for $129 and its definitely worth the money. much better response time and my car idles so much better, havent had a chance to get on the highway yet but its def a must. The amount of smoke from the carbon build up coming from my exhaust was insane lol she breathes a lot better now.
BkGreen97
Apr 2, 2016 05:47 AM
seesole
Sep 14, 2015 12:38 PM
aminus21
Sep 12, 2015 04:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
