Fadanza Flywheel & the 1/4
I'm asking this question because there's speculation that the Fadanza flywheel hurts your time in the 1/4. Is this true? and if so Why?
Seculations:
It chaters at certain RPM's
Upgraded Clutch kits warp the flywheel very quick
High Idle
Unable to luanch vehicle at high Rpm's
Isn't reliable for every day use. (longevity)
Seculations:
High Idle
Makes lauching more difficult. But if you can get the car off the line, the times should go down.
Exactly who do you know has had trouble? Iansw is the only one that I know of that burnt one up. But he was just sitting there at the line burning out the clutch not knowing what was going on.
A couple of guys down here have the fadanza and complained of them warping real quick. Also Tillley has tried this twice and burnt both of them. He told me it wasn't worth the time and money, it's not reliable and doesn't improve time much. The main thing he says is that the 3.5 has so much TQ that the Fadanza just wont stand up to the abuse of track day use.
I had some noise comming from the tranny had to open it back up ( TO bearing
soooo maybe I might get this but I have other plans to add more power. I'm not sure if this would hinder my car and make matters worse.
Doesn't hurt your time it hurts your ability to launch. The line between bog and spin becomes thinner, and you have to be that much better and consistent a driver to walk that line between bog and spin. It doesn't do much for your 1/4 mile time though, there are more effective ways to spend your $500, not to mention install of a flywheel is not exactly fun...
Ok cool I just wanted to make sure and if you say so I know your very reputable on here ORG so I'll take your word for it along with what others have said about it.
Thanx. now back to work on my 12 sec 4thgen.
Not really worth it if your just drag, have had mine for a few years now. Probably would not do it again if I had the choice. What Neal said is just about my feelings as well.
I like it, I have it in both of my fourth gens, but it is harder to launch the car, but for every day driving I enjoy the quicker revs. Both my cars bog easier, and the also shutter if I try to punch it at too low of an rpm.
Originally Posted by vsamoylov
so what is the opinion with it for every day driving?
And as for the 1/4 mile, if you can get the lauch down, the 1/4 mile times should go down. It's simple physics. But don't expect the gains to be the same in each gear.
1st- Tremendous difference
2nd- Very noticable difference
3rd- Good difference
4th- Not so much
5th- Little to no difference
hmm...this thread kinda turns me off the whole thing...too bad, as I was really excited about having a VQ which revs freely...so for everyday driving it makes everything more jerky? and what about just casual driving off a red light...do you have to rev a lot higher or slip the clutch out slower?
I would think that the little weight the fidanza sheds compared to various other aftermarket flywheels, driveability would not be affected nearly as much as you guys are making it sound but I guess it does...
so is the burning up issue a problem if your running a ton of power?
Originally Posted by nismology
Everyday driving is fine. My brother has the "stillen" lightened flywheel in his 2001 and i drive it all the time. The car is much easier to bog when taking off, but after that, it's a cinch. The only other thing is it's harder to make upshifts smooth since the revs drop down so quickly.
4th- Not so much
4th- Not so much
I have a Fidanza + ACT stage 1. I drive in Seattle, (3rd worst traffic in the country) and drop off my baby daughter to grandma everyday. It's harder but only slightly.
IMHO, if you cannot put up with the ever so slight increased difficulty in clutch engagement to reap the benefits of the revs etc.. you can't call yourself an enthusist at all.
Originally Posted by OOmaxSE
since you've driven a max with a lightweight fly, how nice is it when you free rev it? what's the rpms comparable to? would be nice to rev like a street bike.
But it is noticible. My supercharged car hits the rev limiter very quickly, and my N/A one also revs more quickly than the stock flywheel. The car is a little more of a pain to drive but its really not a big deal, if you shift pretty quick you really will not notice very much, but if you are slow in your shifts the revs drop so much quicker you will defintly be in for a bit of a rougher ride.
I think there is alot of placebo effect going on for alot of the guys who say their car revs so much faster with the lightened flywheel. Revs and speed are in a constant ratio while in gear. If you car revs 'so much faster' then that means your car is 'so much faster' but I don't hear anyone talking about how much faster their car is with the lightened flywheel, they just talk about how much it revs.
I've driven cars with identical mods back to back to back with and without fidanza flywheel and the difference is almost unnoticeable. Slightly quicker in 1st gear and not so much in 2nd, other than that there's no discernable difference.
Lightened flywheel is best used for those who rev match on downshifts, which is to say, like 0.001% of maxima drivers. If you are thinking of getting one to help your 1/4 mile performance or anything other than autoX/road course rev matching, I say think again and spend your $500 elsewhere.
Consider this. Car makers and engine builders go to great and sometimes expensive lengths to lighten the rotating masses of the engine and it's parts. But I very much doubt they could take off nearly 10lbs of weight. Especially where the weight is reduced. Why go to these great lengths if there's not benefit?
With that said, I've noticed a differerence with my fidanza. It's pretty apparent in the 1st 2 gears.
Jeff
Jeff
I have had the fidanza flywheel on my car for about 2 thousand miles now and i love it, there really isnt that much of a difference in everyday driving yes a little but its worth it i think, the revs are nuts from first to second and if you ever plan on force induction is when you would most benifit out of all the weight that is not there cuz it will just swing that thing around like nothing then.
I just ordered one from Cattman. I am hoping I like it. I probably will not be able to tell though, cause I am putting in a new engine with the flywheel, so that alone is going to be a BIG difference. I dont care if it doesnt help the performance THAT much, cause it really isnt supposed to make you any faster. I just hope I dont have to deal with it warping, like I read above. That would suck, cause trans problems are not fun.
... Lightened flywheel is best used for those who rev match on downshifts, which is to say, like 0.001% of maxima drivers. If you are thinking of getting one to help your 1/4 mile performance or anything other than autoX/road course rev matching, I say think again and spend your $500 elsewhere.
KabirUTA13
19
Oct 17, 2015 02:15 AM
ag90fox
Sep 9, 2015 12:22 PM
I already got that day off planned.
