anyone thought about upgrading camshafts?
i am thinking of doing this just wondering if anyone has done this yet, i think there would be some good gains with this upgrade.
how much do you think installation would run?
I would be willing to bet, no one has done this mod. Probably the main reason is the difficulty of installation. When I did my dyno I also discussed this same issue regarding the camshafts and told him about the Stillens that claim 15+HP. These guys do serious HP work, engine swaps, superchargers, nitrous, etc.... The mechanic said that it wouldn't be cheap and that it's not a basic install. He talked about some technical things, and where certain things were located and said he wouldn't recommend it for the ponies you get. I looked at the website $1335.00 is pretty steep for 15+HP. With the way he described the install, my guess is labor would run $650-$1,500.
Where are these headers? If you do it, good luck and I'm sure it would be a very noticeable gain, but I just question it's overal HP/$ value. Nitrous would likely be cheaper for sure and a ton more ponies.
PEACE OUT............
I agree Maxmale. If you have the whole set-up the gains will probably be even more significant. I would guess they could reach 30HP or more. Someone with some expertise in this would be able to confirm it though. PEACE
i plan on doing the camshaft install along with high compression heads from nismo.
look into 350z internals and you'll come up with everything and anything.
the high compression heads are 15.1:1 ratio. $2,000 though. and you'll need some extra parts. not sure if nismo cams are a must for them though.
look it up, i'd love to bounce idea's with you guys because im looking to drop some serious cash into the engine bay after i buy the nismo wheels.
- Nick
- Nick
nismo wheels
yes, get the ball rolling on compatible Z oem and Nismo parts! blackpaladin67 found the generic intercooler input used for the G and Z that is on our VQ, although not open.
(thanx tilley for that info) <<he's currently placing a G35-VQ in his older Pathy. Mad Scientist he is, yes.
right on! yeah, nismo gets REALLY expensive though... the wheels should be on in about a month or so...
i say give it a try with the camshafts situation. later on down the road, you'll probably want to switch them out anyways... just my .02 though.
I guess it depends on how you look at this situation. From a financial point of view, it may not be worth the money. I know cams can really wake up a motor, epsecially if they are combined with upgraded intake, exhaust, and other mods. I tihkn they result in more hp if more mods are done. Lets assume you get 25 hp more. At around 1200-1500 for the part, and your own labor, that is about 60-70 dollars per hp. Compared to a simple intake which is arguably around 25 bucks per hp, its expensive. On the other hand, if you are looking for some serious hp, and keeping it all motor, this is not a bad finishing touch. This mod should put the motor well over 300 hp, when combines with intake, exhaust, y pipe, UDP, lightened flywheel and maybe ecu reflash or that safcII thing. It all adds up, baby!!!
15.1:1
Better start thinking of some serious fuel to burn in there ...
I had a comp cams camshaft put in my 99 Grand Prix GTP and the labor was 900 and change. The engine layout is similar in the Max so I'd assume the cost would be the same. For a cam you could call Comp Cams and give them the current engine specs and they could help you come up with a nice grind for probably 400-600 each. The only thing is that you don't know how much power you'll gain or lose until you dyno it as where the nismo is already researched. I'd think with a medium range cam you could get around 15 hp, and if you go want a hot cam i'm sure you could get close to 25-30 hp if you already have an intake and exhaust. I put a medium cam in my GTP and picked up 45 ponies, but having the supercharger increased the gains and I had the computer custom tuned.
350z internals are not different. however the track model parts should be looked into before you do anything you'll regret...
a vq35de motor is a vq35de motor regardless but just double check before you get F'd in the A. lol
And we have 4 cams, not just one 'cam'.
There is quite a bit of work to swap cams on this engine. I looked up the shop manual and with 3 timing chains, 4 cams, varibly controlled pullys plus possibly the hassle of getting the computer to respond to all this. Keep in mind, the engine control section of the shop manual is 690 pages long! Camshaft position sensors, IVT control solenoids..... Not for the faint of heart
- Nick
- Nick
rims
Im trying to sell my heavy azz 20's to my neighbor and go a different route. Im tired of having a slow car....
$1920.00 plus tax..? Damn
Very Serious!
220k+ A32
Sep 23, 2015 03:38 PM
