squeeking clutch
Old May 28, 2001 | 07:35 PM
MacGyver's Avatar
any idea why my clutch squeeks. you can't really hear it unless the car is off or if your in a garage or something.
Old May 28, 2001 | 08:14 PM
Daniel B. Martin's Avatar
Where is the sound coming from? Inside the passenger cabin or inside the engine compartment?
Possible causes include ...
- Lack of lubrication at the pedal pivot point, up under the dashboard.
- Lack of lubrication at the tips of the clutch withdrawal lever or the dimple in the lever where it pivots on the ball joint inside the clutch housing.
Old May 29, 2001 | 05:03 AM
Screaminfast's Avatar
you think it only needs lubrication? My clutch does that too.
Old May 30, 2001 | 06:05 AM
MacGyver's Avatar
i don't know where it is exactly....i press it and it squeeks....any ideas how to fix it? This post in march didn't really tell how to fix it:
https://maxima.org/forums/5th-generation-maxima-2000-2003/27290-broken-locknut-can-t-get-off.html
Old May 30, 2001 | 06:12 AM
i don't know where it is exactly....i press it and it squeeks....any ideas how to fix it? ...
You have to identify the source of the sound in order to make a repair plan. Perhaps you can have an assistant sit in the driver's seat and pump the clutch pedal repeatedly while you listen for the sound. A piece of small-diameter rubber tubing can serve as a listening aid. Listen under the dash and in the engine compartment.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
