Having a problem reset the computer.
I disconnected the battery for 24 hours, the negative part.
Come back and my check engine light is still on.
Any suggestions? Is there any simplier methods other then driving to autozone and waiting for the guy for 2 hours so he can delete the code.
thanks
Gene
thanks
Gene
you're absolutely right as i just realized you have a 2k and i assumed 2k-2k3 had the same procedures. i just reset my light earlier this week on my 2k2 and i followed these procedures. i don't believe it hurts to try. it's hard to follow because it has to be timed exactly, but again, it wouldn't hurt to try.
http://maxima.theowensfamily.com/ecu.asp
edit: i need to add this disclaimer as i do recall someone doing this once. when it says put it in the on position, it does NOT mean to turn it on. just means dont' start, but set it in the on position. someone once turned it on and let the car rev for 7 seconds fully. imagine how dumb they felt.
thanks
Gene
thanks
Gene
umm, yeah... you need to fix the problem before the light will go out.
if theres a little green man holding the elevator on the top floor, the greem man needs to be removed before the elevator will come down... it doesnt matter how many times, or how fast you push the 'up' button.
lets fix the problems, not the symptoms
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
220k+ A32
Sep 22, 2015 03:08 PM
