CEL for P0159 and P0158. How to fix!?
Old Sep 22, 2005 | 09:36 AM
BigL0U's Avatar
As per AutoZone references:
P0159 - Sensor circuit slow response ( Bank 2 Sensor 2)
P0158 - Sensor circuit high voltage ( Bank 2 Sensor 2 )
so now what..i was told this might be the O2 sensor since i had put in a HKS sport exhaust ... and yes the Cat is still on it. Also should i wait for the CEL to pop up again before i take action. Code had been deleted by AutoZone. Please advise thanks.
Old Sep 22, 2005 | 10:34 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
a catback should nothing to do with this code. your code is for a secondary o2 sensor which your 2k1 cali spec car has two of. both are before the main cat so unless someone was just really careless then you just have a bad o2 sensor. if it is truly bad then the code will cycle back out.
Old Sep 22, 2005 | 10:41 AM
Epacy's Avatar
Unsuccesful STL Coordinator
First thing to do would be to look at the threads that already cover this topic.
Old Sep 22, 2005 | 10:46 AM
danger300z's Avatar
i had they same code and i replace my o2 sensor , then the problem was gone.
Old Sep 22, 2005 | 11:49 AM
BigL0U's Avatar
thanks ... how much would it be to replace the 02 sensor? any highly recommended?
Old Sep 22, 2005 | 01:36 PM
sloppymax's Avatar
check them out at www.oxygensensors.com they had the best prices last time i replaced one.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
