Muffler install questions? ASAP!
Old Sep 24, 2005 | 10:03 AM
ecko51's Avatar
Help.
Can you install a muffler with out a lift.
I just removed my stock cat bak. The flange at the end of the muffler rotted away so the muffler came right off.
Now I have the b pipe on and can't get the muffler throuh the rear arm opening. The flange get's in the way.
Can it be done if so how.
Thanks, Mike
Old Sep 24, 2005 | 01:22 PM
99 SE-L
Originally Posted by ecko51
Help.
Thanks, Mike
Rear arm opening? are you installing an aftermarket muffler with the stock B-Pipe?
Old Sep 24, 2005 | 01:47 PM
ecko51's Avatar
No.
Greddy Cat-back.
I wound up loosening the 5 17mm bolts the hold the arm on about 3/8 of an inch . This made the area that the pipe snakes through large enough to get the flange through.
The rest was cake and it's all good now.
Mike
Old Sep 24, 2005 | 06:16 PM
irish44j's Avatar
retired moderator
it can be done, but you need to get the back of the car WAAAYYYY up there on the jackstands. I mean, as high as a floor jack will go, and then some. The big tip on the Greddy will make it even harder to do compared to say, a Frankencar.
but it can be done. turn the muffler sideways and try various positions to get it though the axle tunnel. It takes 2 people and the back wheels need to come off or they'll get in the way.
trust me, I've done it twice.
Old Sep 24, 2005 | 06:18 PM
GBAUER's Avatar
The home depot mod king speaks. All shall listen.
Old Sep 24, 2005 | 10:56 PM
SEmy2K2go's Avatar
Go BUCKS!!!
This gives you an idea how high you need to get the car.
Pictured my car while installing my Cattman catback.
Old Sep 25, 2005 | 12:48 PM
Puppetmaster's Avatar
Like already said... wriggle it around with the car jacked high up and it'll come off.
http://forums.maxima.org/showthread.php?t=422651
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
maxfever1987
Nov 19, 2016 08:01 PM
erictown
Aug 20, 2015 08:01 AM
doobadoo
Aug 15, 2015 06:43 PM
