Which Exhaust Gaskekts Needed for.......
Old Oct 5, 2005 | 11:12 AM
wanta02max's Avatar
.....Y-pipe installation? I will be installing a Stillen Y this weekend and was just curious if I picked up the right ones from Nissan. They told me I needed 1 small ring gasket (for the cat) and 2 flat diamond shaped ones coming off the headers...is this right or not?
Old Oct 5, 2005 | 11:48 AM
Puppetmaster's Avatar
I'm pretty sure you need 2 ring/crush gaskets... one for between the y-pipe flange and the front manifold, and one between the flange and the rear manifold. Between the y-pipe and the cat, you need one of those regular exhaust gaskets that look like this:
If you use OEM gaskets, ya might have to cut em bigger to match the 2.5" diameter of the y-pipe since the stock y-pipe is 2".
Part numbers are here if ya need em:
Old Oct 5, 2005 | 02:22 PM
wanta02max's Avatar
sounds like they got them backwards then...
Old Oct 5, 2005 | 02:26 PM
Yup... and when I said cut em bigger, I meant the gasket pictured, not the ring gaskets.
Old Oct 5, 2005 | 03:48 PM
wanta02max's Avatar
yea i gotcha...thanks
smplyamzng
Dec 13, 2015 01:19 PM
maxinout93
Aug 20, 2015 02:17 AM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
