Help! Major electrical system failure.
Old Oct 12, 2005 | 08:52 PM
Powerman5115's Avatar
I just installed the '00VI. I took the battery out and put it back in the wrong way, as the terminals were backwards. I did not try to crank it like this but when I was connecting to the terminals the negative cable sparked twice. Then I figured out it was backwards. I put it back right and went to start it. It cranks but it does not even idle, just dies but I can keep it running it I rev it. My dad says if feels like a cylinder is misfiring I felt the same.I checked and rechecked for vacuum leaks and make sure all connections were correct, I found nothing out of the ordinary. I also hear a weezing coming from the engine bay, I couldn't pinpoint it out. My dad and I figured it's an electrical issue. My stereo, wipers, alarm, keyless entry, lights on the doos, and air condition/fan do not work. I checked the fuses of the things that did not work and they were fine. My dad says there should something like a central fuse connecting to everything that would have blown. I hardly know anything about the maxima's electrical system. I need help. Please.
Thanks,
Mooney
Edit: I have not checked for codes yet.
Old Oct 13, 2005 | 08:38 AM
bump...1234
Old Oct 13, 2005 | 08:47 AM
2 Da Max's Avatar
did you check the main fuses under the hood? i know their is a main fuse for the batt. to the other electical components.
Old Oct 13, 2005 | 08:52 AM
wikidminds's Avatar
check fuses....check for codes...then post back with results
Old Oct 15, 2005 | 01:21 PM
Checked fuses and replaced the main battery fuse. Ran car again, same problem. The stereo and keyless entry does not work. I checked all the fuses and used a tester to make sure the fuses were getting power, they were. Can relays go bad? I don't know what to do.
Old Oct 15, 2005 | 01:26 PM
Bobo's Avatar
Does the 4th Gen Maxima have any fusible links?
Old Oct 15, 2005 | 05:42 PM
Yes. I changed the main battery one, and that fixed most of everything. All that doesn't work now is the Keyless entry and anti theft system.
Mooney
Old Oct 15, 2005 | 06:06 PM
RockfordMax's Avatar
Back from the dead
sounds like a BCM problem. look for a fuse for that maybe?
Old Oct 15, 2005 | 09:55 PM
I replaced the security light fuse. That worked.
Mooney
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
