Strange happening during seafoam.
Old Oct 14, 2005 | 02:18 PM
FormorAccordMan's Avatar
I had my brother inside bliping the gas while I had the vacuum hose sucking it in. While it was slowly sucking it in the smoke started to pour out the back, but then i noticed that there was a little smoke coming from the rear of the engine!I was like WTF. I really don't remember this happening last year when I did it. The car runs well. Idles rock solid and seems quieter/smoother than before, but after seeing the smoke come from somwhere in the engine bay during the process, I am kinda nervous. I could not see exactly where the smoke was originating from.It was nowhere near the amount pouring from the back, but still, it was noticable. Anyone?
Old Oct 14, 2005 | 02:39 PM
maxspeed96CT's Avatar
The original VQ...
ya some people said their car smoked alot, and some said they didnt see much smoke.
When i did it, it wasnt as bad as the smoke in some of the pictures i saw.
Old Oct 14, 2005 | 02:44 PM
Did you car smoke a little under the hood as well? thats what I am talking about.
Old Oct 14, 2005 | 02:46 PM
mtrai760's Avatar
'Trynna' is not a word
Maybe it was coming back under your car and up through the engine bay from the exhaust?
Old Oct 14, 2005 | 02:50 PM
goldtooth's Avatar
Or maybe, just a CRAZY idea.... there is a leak somewhere ? Don't some people use the seafoam to check for leaks ? (At least I heard some do that)
Old Oct 14, 2005 | 03:00 PM
Oh ****. You said the L word. I was really hoping that was not it. But I could not see any definative place where the smoke was coming from. If everything is correct, there should NEVER be any smoke coming from around the engine bay durring a seafoam treatment unless there is a leak? Argh. If there is a leak, that means its robbing me of power!!
Old Oct 14, 2005 | 03:02 PM
MDeezy's Avatar
you shouldnt see it anywhere but out of the exhaust if you see it anywhere else, they maybe a leak there.
I recall seeing some smoke undermy hood when I first seafoamed (about a year ago) thought I might have a leak but never investigated. Everything still smooth a year later.
Old Oct 14, 2005 | 03:17 PM
deezy- how bad was the smoke? Do you think that you car is at a major deficiency right now because it might have a leak? How the hell can I find the damn leak? It just seamed to be coming somewhere from the rear of the bay. I dont' want to run another seafoam through tthe engine again. Just how bad is having an exaust leak? Should I not worry about it if the car still pulls hard and idles smooth? I was always told that "if you have an exaust leak- you'll know it", the car will run like ****.
Old Oct 14, 2005 | 03:32 PM
MDeezy's Avatar
smoke wasnt that bad, but it was noticable. My car ran like a champ afterwards, a few days later after not noticing anything wrong or a cel I let it be until something happened. . . which it never did.
If you had a leak it should produce an odd sound, starting the car, and revving the engine while your underthere and listening should help you determine where it is. I think you probably dont have a serious one and will be fine leaving it alone for now but keeping and eyeon the situation. You said your car is running excellent, leave it be but keep and eye on it.
there may be a produc to help expose leaks but I wouldnt know of one. maybe fluids section could help.
Old Oct 14, 2005 | 04:34 PM
Deezy, I really don't hear anything odd when starting the car.It sounds perfect. When you sit in it with the windows up idling, you can barely tell its running. When I rev the enigine, with the windows down, I hear an air wooshing sound, but i just attribute that to the intake sucking up air. (stock intake with a k and n drop in)
Old Oct 14, 2005 | 04:37 PM
Jeff92se's Avatar
I'm needing a caw
You are obviously leaking the the smoke from somewhere from where it's formed to where it's leaking. Not rocket science. Could be leak at a flange, or the flex section. But more likely at an exhaust flange.
Old Oct 15, 2005 | 12:38 AM
eLMo's Avatar
You press the gas and have a vaccum cleaner on the exhaust? I'm confused, why do you guys do this?
Old Oct 15, 2005 | 06:25 AM
njmaxseltd's Avatar
Wind probably blew the smoke back under the car and it came up into the engine compartment. Don't worry about it, if your exhaust was leaking, you'd hear it.
Old Oct 15, 2005 | 08:12 AM
mizmo21's Avatar
yea... dont know what seafoam is and why u use a vacuum?
Old Oct 15, 2005 | 08:48 AM
Jatan's Avatar
Happened to me (some smoke coming from under the engine), but I know my flex is messed up - did it on my mom's Civic and nothing came up from under the engine
Because you need it
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
