Can your A/C Compressor leak?
Hi All,
I have a fluid leaking form the right corner of my car. I'm pretty sure it's not windshield fluid, brake fluid, tranny fluid, engine oil, or powersteering oil. The leak seems to be coming from the A/C compressor, but I'm not sure if there's anything in there to leak? I know there's freon but I wouldn't think that would leak consistently for 3 weeks and the A/C still works fine.
Any ideas? The fluid is clear andnot really oily.
Any suggestions or tips would be appreciated. Thanks!!!
TJ
TJ
yep i had a leak in mine all the freon went byebye. had to replace the compressor. it leak for quit awhile. untill it a/c was just blowing hot. if you can get a rebuilt one for cheaper.. or look on here for someone selling one
condensation off the A/C evaporator?
edit: i know phase change(refrigeration) systems pretty well. a leak in the compressor would not leak any liquid refrigerant. and if it did, it would evaporate VERY quickly. for an example turn a can of compressed air upside down and fire some on a table or something. youll notice that the liquid goes away very fast and leaves a cold spot.
how much fluid is on the ground? reason i ask is an A/C wont have much refrigerant in it at all. at absolute max i would say you could fill a 12oz soda can about 1/4 of the way with it.. if it were possible to keep it a liquid.
in english: its not "freon"(term is no longer used. now it is refered to as something like R134a.) there isnt enough in the system, and it would evaporate immediatly if it were leaked on the ground as liquid.
you won't see the "freon" on the ground in liquid form. so what ever you are seeing is not the refrigerant (which you refer to as "freon") from your ac. unfortunately i don't have any suggestions as to what it might be.
yeah i wouldn't think its the refrigerant either because the liquid doesn't evaporate away. every morning for the last few weeks i've seen a small pool of liquid maybe about 3x6 inches.
i guess i gotta jack up my car and figure out where the heck it's coming from.
the liquid isn't oily. if i take it and rub it between my fingers it'll dry up with a residue left on my finger. i'm not sure if thats understandable.
but how much oil does the a/c system have? and what happens if the oil leaks out completely?
a very small amount really. a large compressor is smaller than a basketball. the refrigeration system for my computer uses a 1/2 HP compressor. it has 8oz of oil in it. our cars im sure use a much smaller compressor, likely around 1/8th HP, so.... not much oil at all.
knowing what i do about refrigeration, i would say it is NOT an A/C problem. if it was the system would not work at all. the A/C would fire hot air.
it could be window washer fluid, the soapy stuff leaving the residue? my best guess.
litch
123
Jan 4, 2024 07:01 PM
mclasser
Sep 24, 2015 11:57 PM
