High pitched noise when accelerating?
Old Oct 16, 2005 | 12:03 PM
fadeaway's Avatar
Go Hokies!!
I have this extremely annoying high pitched noise coming only when my head unit is turned on. It gets higher when I accelerate more (when RPM's get higher). One of my friend's told me it could have to do with "grounding" my HU.
Does anyone know what the cause of this is? It's been doing this for about a year, and I'm geting extremely sick of it.
Thanks,
Dan
Old Oct 16, 2005 | 12:18 PM
SC2K1's Avatar
Sounds like alternator whine. Do you have an amp? May want to check your grounds. This post may help:
Link
Some of our resident experts may be able to add more.
Old Oct 16, 2005 | 05:00 PM
fadeaway's Avatar
Go Hokies!!
Thanks. I just actually remembered my ground wire connecting to my speaker amp is currently disconnected. Is there a good chance this is causing the sound? I haven't hooked it back on since the peice which clamps the wire down fell off apparently.
Thanks.
Old Oct 16, 2005 | 05:23 PM
SC2K1's Avatar
Thanks.
Possibly but I'll let the experts chime in.
Old Oct 16, 2005 | 06:01 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
and its working for you? Id spend the 1.99 and crimp and ground it properly. If that doesnt work try either a new ground, or grounding the rcas.
Old Nov 5, 2005 | 10:24 PM
quique's Avatar
and you have the power wire to the amp still connected? if you do definitely connect the ground back up. if that doesnt do it check the ground on your head unit
Old Nov 5, 2005 | 10:42 PM
descent's Avatar
no ground??? ===========(
Old Nov 5, 2005 | 10:54 PM
AscendantMax's Avatar
check and SECURE all grounds.
Old Nov 18, 2005 | 03:41 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
99.9% of the time, alternator whine is caused by a bad ground. check all your grounds.
Old Nov 18, 2005 | 03:49 PM
MannyNJ2k2max's Avatar
Could be a bad HU to chasis ground or bad internal HU ground..
Old Nov 19, 2005 | 07:14 AM
jigga123's Avatar
x2 very popular problems with Pioneer HU's
lrb6805
Sep 30, 2015 08:12 AM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
Justin Kroll
Sep 2, 2015 11:06 AM
