motor weight anybody?
wait, didn't jclaw say he weighed his vq35 and it came out to be 175-200lbs? correct me if i am wrong jclaw...
and I thought the vq30 was 30lbs heavier than the vq35...not 45? sorry, i'm bored tonight
I do not know how JClaw came up with his weight. If he went with the shipping weight on a packing slip, those are bogus. When the guy dropped off my engine, I asked him how much it weighed. He said "All engines weigh 200#". (ie. It is just a standard weight they use for shipping purposes)
I had my engine practically stripped down to the block and weighed the components on a shipping scale I borrowed from work.
block, crank & oil pump - 118#
both heads with valves installed (no cams or lifters) - 50#
front&rear timing covers + bolts - 23.5#
cams, lifters, sprockets, tensioners, chains, etc. - 34#
LIM, upper & lower plenum & throttle body, front engine mount - 36#
I just realized I never weighed the pistons & conn. rods. That would not amount to much more than about 6#. They are pretty light.
So lets say 270-275# for a VQ35 with no flywheel or accessories.
The vq 30 valve covers are heavy because i know the vq35's are 8lbs lighter right there over VQ30's i weighed them at tilleys on a scale that measures in grams. think of that just the valvecovers save 8lbs
Originally Posted by krismax
heres no way the vq30 is close to vq35 weight even nissan says vq 35 is 30+ lbs lighter.
I have a VQ30 (less flywheel) sitting in the corner of the garage. I just need to rig up something to get it to balance on the scales.
I agree. Both valve covers, spark plugs and bolts weigh in at about 2#. There is also a huge weight difference between the flywheels, which was not included in my measurements.
But i weighed 2k2 IM over 00vi and and believe it or not the 2k2 upper is much lighter but the lower is heavier than 00vi's lower. But i bet dek engine is lighter than 3.0 because even the dek's lower is a few lbs lighter than reg vq30's
I know a VQ35 is one heavy beast, my friend and I were trying to put it up on a bed of a pick up truck and we needed help!!! it didn't have ac compressor, and motor mounts...THATS A HUUUUGE BICH!!
A friend and I had no problem lifting by hand a VQ35 on a pallet into the bed of a pickup truck. It had no accessories on it and had the exhaust manifolds taken off. Didn't "feel" heavier than 200lbs. Basically, it felt like it weighed the same as a 4 banger with a cast iron block.
Try lifting a VE30DE with two people. Superman and HeMan couldn't do that. haha
200-300lbs. I tend to think it's on the lower end of the range. We do know that the VQ35 is 35lbs lighter than the DE-K or the DE. If you put the VQ30 flywheel on the VQ35, it'll be even lighter.
How much does a VE weigh? Like 500lbs?
This site has good info, except engine weights
http://www.freshalloy.com/site/featu...nes/home.shtml
This article says towards the bottom that there's only a 64# savings versus the previous engine but alot of their info doesn't look very accurate:
http://www.internetautoguide.com/rev...n/maxima/1994/
So a DE-K is probably slightly lighter than a 30DE due to the IM, right?
And so are 5.5 gens slightly lighter overall than 5.0 gens? Probably improves front/rear weight distribution and handling and hurts traction.
01 Maxima SE 5spd: 3199lbs
02 Maxima SE 6spd: 3224lbs
(from autos.msn.com)
It appears the weight difference between a 3.5 and a 3.0 is not as much as originally thought. Scale was recently calibrated and accuracy is +/- 0.5 lbs.
This is a scale that was rented for an audited year end inventory.
Considering the original numbers that I had, I think it is time to get our shipping scale recalibrated.
No flywheel, exhaust manifolds or accessories on either engine.
You can deduct 3 lbs off of the display for the weight of the rope and engine slinger.
The 25 lbs. weight differential is even less because of the UDP on the 3.5 and the 3.0 is still full of oil and has the engine harness attached.
The IM on the 3.0 is just sitting on the top of the engine. It was a lot easier to unbolt it to install the rear engine slinger.
EDIT: To avoid anymore posts like the two below, that is a Fram oil filter on the 3.0 and a Nissan 15200-65F00 on the 3.5.
Originally Posted by SR-71 Blackbird
that fram filter on the VQ30 sends chills down my spine.
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
so many # flying around in here.
