Possible idler pulley issue
I just changed out my altenator and put on a new belt... Belt/pulley still has a squeal to it. Two questions, is it possible to over tighten it and what would be the effects be, also how can I tell if my pulley is bad? My mech buddy suggested that could be the issue. If the pulley is bad do I just need to get a new one, take off bolt, washer and pulley to replace?? TIA...
I broke mine when I changed my UDP. If you go to Nissan it should be around $40- they will give you the pulley, the washers and bolt with nut. Probably the only way you will find out if you've gone too far is when it breaks. or starts tightening up alot. That's what mine did and then the bolt snapped.
You can easily overtighten it. You will hear an annoying
noise.
Adjust the the tension first and see if the sound goes away.
If it's still there you can take the belt off and start the car
just long enough to hear if the noise is there.
If the noise goes away chances are the bearings are going on the
pulley and you will have to replace it. Mine didn't go till I hit
290,000KM.
noise.
290,000KM.
Yes, you have to loosen the bolt that is in the center of the pulley before you can effectively tighten or loosen the bolt that goes down in behind the pulley. They both should be 14mm.
Mar 12, 2020 12:06 AM
BrandonCause
Sep 14, 2015 10:41 PM
