cracked/broken injector plugs
Old Oct 21, 2005 | 10:33 AM
vansskaterfreek's Avatar
my injector plugs stil stay connected, but the platic housing that holds them on are broken...all of them i can just pull them off and they come off..pretty easily i might add....is it worth buying new injector plugs?????since they are not a problem now should i just leave them??
Old Oct 21, 2005 | 11:03 AM
Greeny's Avatar
¯\(°_o)/¯
If you have holes in your underwear,what would be the sensible thing to do??
Old Oct 21, 2005 | 11:40 AM
tighty whities are not my thing... LOL....well what i was saying is that since there is not any problem with them in rain or anything....would they be ok? i am putting in the new tranny soon and now i am super low on money...if i change the plugs, should i change the injectors since my car has unknown mileage????? when i pulled my spark plugs out, they all were differen colors and my dad said that only one of them was the right color..the others looked like they were running rich..woudl changing the injectors also change this problem.... i have Bosch Platinums
Old Oct 21, 2005 | 01:18 PM
eric93SE's Avatar
On the VG the connectors are known to get corroded. I think Jeff has the part number, there is probably a generic part number for them as well. Check the connectors for oxidation, if they have even the slightest amount of corrosion it will definitly hurt your maxi-pads performance.
Old Oct 21, 2005 | 02:43 PM
Jeff92se's Avatar
I'm needing a caw
Try to smear the inside of the connector with dielectric grease. That might "hold" them in well enough. Not the greatest solution but.............
Old Oct 21, 2005 | 04:55 PM
eric93SE's Avatar
yeah, I wouldn't do that. remember dielectric grease is an insulator.
If you want to get rid of the corrosion you can use some baking soda in warm water with the help of a small paint brush. then wash the solution off with some warm water (not a lot, engines don't like water ) then air dry (compressed preferably).
To keep the connectors on, I would (after everything is dry) use a dab of silicone rubber on the outside of the connector (front or side, wherever is accesible). don't use too much otherwise you'll never get it off, but if you use a small amount and make a button out of it, it should be good (you should be able to peel it off in the future).
Old Oct 22, 2005 | 06:20 PM
internetautomar's Avatar
mod or sell?
if the connector breaks and you have the pieces try using model cement to hold the pieces together
Old Oct 23, 2005 | 01:08 AM
Wiking's Avatar
Originally Posted by vansskaterfreek
tighty whities are not my thing.... i have Bosch Platinums
That says it all. Take them *6bosxh* out, try hittin magpies... plug in with NGK. (Well, seems u have one good, keep that as souvenir for u gran kids)
Nobody 'needs' connectors, theyre just a craking nuisance. However, conductance is imperative in this issue. In goes the mentioned contact grease, and strap em wires so that they have no way out.
Old Oct 23, 2005 | 01:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
are you sure you're not missing the metal clip?
if the metal clip is on and the injector is just falling out then it's not your connector that's broken..it's your male connector on the actual injector that's broken.
Old Oct 24, 2005 | 12:12 PM
there is one of my injectors remember it doesnt fall out, and hever has (that i know of) i was just concerned about it
Old Oct 24, 2005 | 12:42 PM
Jeff92se's Avatar
I'm needing a caw
That's great that you wouldn't do that. But if you want a connector with green ooze like the picture above, that's what you are going to get. I suggested using the grease in the areas that the connectors slide against. This does not affect the connection and will effectively seal the connector.
It's common practice to use dielectric grease on all electrical connectors.
Old Oct 24, 2005 | 12:48 PM
Greeny's Avatar
¯\(°_o)/¯
Vans...While your car is down,go though all the electrical connectors and sensor connectors on the engine and check them for that green crap...I found alot of that on my car a few yrs. ago...I cleaned them all and the car seemed to run and idle smoother....
Old Oct 24, 2005 | 06:20 PM
LOL get this, i just noticed that green crap...didnt catch my eye earlier.....so just some dielectric grease will work find to get rid of that stuff???? alright, cool.........i am changing the y-pipe studs tomorrow / wednesday..i cannot find the nuts and cannot get the old nuts off of the old studs. i found some nuts that fit the coarser thread, but cannot find any of the finer thread.....i guess its time to go back to sears again
Old Oct 24, 2005 | 06:25 PM
Greeny's Avatar
¯\(°_o)/¯
No..You need to get a can of electrical parts cleaner,and a stiff bristle toothbrush to get that green crap off there..Then put some dielectric grease on them...
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
