New to 5 Spd Need Advice
Well I am new to the 5 speed and aint very good at starting on hills. I roll back alot and was wondering how do you guys keep from rolling back?
Originally Posted by white97gxe
I also heard you can put up your handbrake and start up like you normally do, and relase the handbrake when you feel it catch.
practise start with half clutch ... keep brake and clutch while starting and give more gas. with enough practice u ll be doing what chenzarino is saying
try it a lot of times man ....and u ll find it easy
just my 0.02...
just my 0.02...
Yea true I am thinking about lowering my clutch pedeal closer to the floor because it seems I have to let the clutch pedal halfway out before it even grabs where does yours grab at?
When I first got my I30t I had a real hard time with the gear changing and taking off...I have driven MANY manual cars, I work at a dealership and I work w the used cars...but for some reason it took about 4 months to really get used to driving my I30. I recently changed the clutch and it got better because it was no longer shaking the **** out of the car on take - offs due to old clutch I guees.
Originally Posted by maxgtr2000
Practice, practice, practice, you'll get it.
i use the ebrake sometimes on hills to prevent rolling. is it okay on the clutch for you to hold the car on a hill using the clutch and not the brakes? i thought it wasn't which is why i ebrake.
As I said before, find the friction point of the clutch. It does not burn up the clutch if you hold it there as the clutch is not fully engaged. Plus how often are you going to do this?
Burns up the clutch
Practise is the best thing. Another technique if your footwork isnt that fast, is hold the ebrake, and then gas let off clutch and when you feel the resistance slowly let off the ebrake and drive forward.
Another way (not good) rev to 1.5K and come off clutch slowly, you'll burn it up, but better than rolling back too far, the car behind you runs into you.
quick, percist feet come with practise.
le the clutch out until u see the RPM's drop a lil then slowly take ur foot off the brake until ur only foot left on the pedals is ur clutch. U shouldnt be moviing, then when the light turns green hit the gas(to about 2 grand) and slowly let off of the clutch it will work EVERY TIME
What? LOL
Hahahaha..
Waaaaayyyyy too technical.
You simply practice letting the clutch out and giving it a little more gas until you feel it take hold.
So, you typically have right foot on brake, start letting out the clutch, when it starts to engage, move you right foot over to the gas and start giving it more gas.
Then again, I've been clutching for 30 years or so. I don't need to use the brakes to hold my car on a hill but I do anyway because I don't want to slip/burn the clutch very long.
As most have said, just practice. Practice on a slight incline hill, not a major hill. As you get more proficient, move to a bigger hill.
As many others have said, you should practice this, but it's the best way to save your clutch, AND prevent you from rolling back.
Originally Posted by Supermax95
brake and let go of the clutch slowly til you feel it grip and hold it, then let go of the brake quickly and hit the gas/let go of the clutch.......
I do that but then again I probably rev it to 5000
just go by the feel of it man, turn the radio and ac off and listen for the rpms to drop as you let the clutch in smoothly, feel the vibes in the pedals, steering wheel, and shifter as the engnie starts to stumble a bit, its asking for a bit more gas there, react by giving it a bit.
just sorta go with the flow until your used to it, there is no trick thatll make it easier really
at least we're not driving up to Lombard St. in San Fran on a busy day
http://www.sftravel.com/lomabardcrookedstreet.html
How do i adjust the grab point do i screw the screw in or out
behind the clutch pedal you'll see a shaft that goes into the firewall, that will need to be rotated clock wise (lower grab point) or coutner clock wise (raise grab point). Follow the shaft back towards you, you'll see a large nut that will need to be losened in order for your to rotate the shaft. Dont forget to tighten the nut back when your done.
If my description sucks there I believe the one in the how to's or faqs maybe better.
ef9
Oct 4, 2015 08:43 AM
