Air coming out vents all the time?
Why is there air coming out of the vents in my car all the time? I got the control off but there always air coming out. I have a manual climate control system
What? Unless you have RECIRC ON, you'll always get air thru your top vents as you drive....Get/read the manual, man
Same thing here but I only feel it on the highway
http://forums.maxima.org/showpost.ph...2&postcount=31
Originally Posted by 96customax
yeah a little bit of air always comes thru.. dont feel bad my air will only work on 4
It's supposed to blow fresh air all the time. How do you think they keep the car's exhaust gases out of the cabin? The HVAC systems should always bring fresh air into your car. There are direction control air vent valves in your quarter pannels to control air flow through the vehicle. Keeps you from getting killed by your exhaust. Keeping the system off by using the REC mode will also make your windows fog up when their closed.
Think about it... when your traveling at faster speeds, more air is moving by the car. The intake for the climate control system is getting blasted with more air, so naturally more air is going to flow through....
(I'm going to feel really dumb if this is a wrong hypothesis)
mine blows through the floor vents at high speeds.....the cool thing is at high speeds the fan slows down cause it has so much air moving throug it.....but the little fan thingy still has 4 blades lit up....are they like dual stage blower fans or something
Hondarydr
Dec 30, 2024 06:15 PM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
