valve body question
Just about any tranny mechanic familar with high performance should be able to mod a Maxima VB. All thats done is a pressure increase by drilling out a few bores. If you know the VB, it's easy to see 1st and 2nd gear fluid bores which are usually the ones that are changed.
so is it possible any could do this??
Valve Body Mod
Description: For automatic transmissions only. Makes the transmission shift quicker between gears. And even though the shifts feel harsher it actually prolongs the life of your tranny. Known to decrease 1/4 mile times by .1. It is also recommended that you get a tranny cooler if you do this mod since it causes your tranny to run hotter.
i got this from the maxmod website, Decrease by .1? for 400? ... dam so i fi run 15.3, ill run 15.2... i guess getting an upgraded ecu is smarter than
03VQMAX
Sep 5, 2015 03:47 PM
