94 Nissan Altima Dyno vid
G35 Stock
Altima (too much ****, but the main stuff is)
OBX 4-2-1 header
clogged cat
custom catback
CAI
Apex-i S-AFC II Tuned
75 shot NOS Wet kit
MSD SS Blaster Coil
MSD 6+ controller
10.2mm wires
NGK 7 series plugs
Nismo Adjustable FPR
Fuel Pressure gauge
Walbro 255lph pump
and some other misc ****
OBX 4-2-1 header
clogged cat
custom catback
CAI
75 shot NOS Wet kit
MSD SS Blaster Coil
MSD 6+ controller
10.2mm wires
NGK 7 series plugs
Fuel Pressure gauge
Walbro 255lph pump
Originally Posted by Nissan Love
G35 Stock
OBX 4-2-1 header
clogged cat
custom catback
CAI
75 shot NOS Wet kit
MSD SS Blaster Coil
MSD 6+ controller
10.2mm wires
NGK 7 series plugs
Fuel Pressure gauge
Walbro 255lph pump
OBX 4-2-1 header
clogged cat
custom catback
CAI
75 shot NOS Wet kit
MSD SS Blaster Coil
MSD 6+ controller
10.2mm wires
NGK 7 series plugs
Fuel Pressure gauge
Walbro 255lph pump
Haha...as a Max/Altima owner I can tell you w/i a few hp....1st gen Altimas put down a mere 111/125whp stock (auto/manual) and with bolt ons, autos put down ~140whp (I/H/E), more w/tuning, cams,etc...and manuals in the 150-160whp range depending on extent of mods...My '93 auto Altima dynoed 111whp/130tq stock and 144whp/150ishtq w/intake/header and Max muffler.
Most of the turbo Altimas running on the forum put down mid-high 200s, with a few running around 300-320ish whp(running 12.7s 1/4mile) and one or two close to 400whp w/built engines....
Sorry for the OT but you wanted info
my car off juice puts down 136whp. that was with a clogged cat (still clogged), so im guessing once it frees up, i will be around 140whp. I should be turboed soon if things work out correctly. I never ran this car on a dyno when it was stock, so i dont know what it would have made at that time
Originally Posted by NmexMAX
Run files, you should be able to get them from the shop you dynod at... I'd be interested in the G35 files.
run files are better than a chart posted...
You have one strong auto.His trapped 97mph at the track though.
Run files let you look at any data incrememnt captured (RPM/SPeed/HP/TQ/AF in very small or very large increments) all with relation to speed/time/rpm.
But the file let's you do it at your own discretion ....
Vid 217whp 204ft lbs
I gotta get the G's Vid edited so its not so lengthy, but the G put down 244RWHP
you got 217whp and 204ft lbs????
You should have 230-260ft lbs.
Bowzer, erebuni, what's his face( the guy with the wrapped CAI that live in miami and got 14.8), they all got more than 220ft lbs and some of them have 30whp less than you.
We were referring to the G35, since it has much more maxima relation than your spraying alti
The G put down over 240ftlbs, the altima has the low torque for some reason. But i think it was because of low nitrous pressure.
and the G running low 15s was mostly due to the heat on the track. most cars were running between .5-1 sec slower than normal. some even a lil over a second
I've had TQ ratings prior in the 250ftlbs range, but that was with everything at full strength. I hope to dyno again soon after i fix some issues i have with my bottle heater and see what i put down then. My guess is somewhere between 220-230whp, and 240-260ftlbs
are you smoking anything your employer should know about?
