Bbbbbaby - it's cold inside!
Old Nov 2, 2005 | 12:32 PM
RyderMax's Avatar
Can someone tell me why, when I have the temp pushed up to 28C, it's blowing very warm air into the defroster, warmish air onto the feet, but d**m freezing air out of the centre air vents?
Winter's coming, and I'd like to be able to be warm this year!
M
Old Nov 2, 2005 | 01:11 PM
bhunter's Avatar
It sounds like the fresh air lever to the far left is in the open position.
Old Nov 2, 2005 | 02:12 PM
mtcookson's Avatar
i.e. make sure this lever is pointing down when you want heat
Old Nov 2, 2005 | 02:37 PM
Krannick's Avatar
exactly the same problem i posted a week or two ago
http://forums.maxima.org/showthread.php?t=436555
Old Nov 3, 2005 | 04:13 PM
RyderMax's Avatar
Yup.
Boy, do I feel foolish. Who knew there was a lever there? Well, obviously you guys did.
Guess I gotta rtfm once in a while.
Old Nov 3, 2005 | 05:33 PM
DennisMik's Avatar
we all love those easy fixes!
Old Nov 3, 2005 | 05:49 PM
jhenry330's Avatar
I have a problem with heat too this year, but I am afraid its not that switch. My top heater hose running into the firewall is hot and the bottom one is cold. Sound like a heater core plug up?
Old Nov 3, 2005 | 07:13 PM
mtcookson's Avatar
yup. when that happens i just hook up a garden hose to them. one on the top, one on the bottom. flushes all of the nasty junk out and makes the heater work great. that's what has always worked for me.
Old Nov 3, 2005 | 10:31 PM
maximagxe90's Avatar
my heater has been good since my coolant system was flush last year,
i have heat after 15-30 minutes,
Old Nov 4, 2005 | 01:14 AM
Wiking's Avatar
Originally Posted by jhenry330
...Sound like a heater core plug up?
First the easy -IF- ...with the Valve:
- Vacuum hose to intake ok
- hoses connected properly
- one way valve works
- electric/vac valve works, gets signal
- valve actuator works
- valve really opens...
see http://www.cardomain.com/ride/748507/8
maximagxe90 "...i have heat after 15-30 minutes,
- Nogood: Tstat stuck, swap
Btw. Why not read the forum? 'Each one' of the ten pages has 2threads on this issue?
Old Nov 4, 2005 | 05:22 PM
jhenry330's Avatar
Thanks for the info guys! I noticed I am missing the one way valve on vacuum line to the manifold. I'll try that garden hose trick too with a flush. Thanks much
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
TKHanson
Nov 24, 2018 01:39 AM
