Sponsored by:
Sponsored by: CARiD
Skunk2 plenium spacer
Old Nov 2, 2005 | 03:15 PM
maxmale's Avatar
I was reading import 2nr today and say an article on this plenium spacer supposed to add 10-10+ HP. They said it is for the 350 and g35, was just wondering if these may fit our cars. It just looks like an extra thick gasket.
Old Nov 10, 2005 | 11:16 AM
super6's Avatar
also curious? i used to have a mustang and losts of the mustang guys had these, where to get one for a max?
Old Nov 10, 2005 | 11:22 AM
NmexMAX's Avatar
dot dot dot ...
Old Nov 10, 2005 | 11:28 AM
virgilio7's Avatar
for the z and g is the only application. the reason being is that the runners at the back of the intake manifold doesn't get too much airflow so if you install this, the runner will lift just a bit. enough to get more airflow into the lower intake manifold and equilize the airflow between all the runners. for our type of setup the intake manifold is not restricted by height. is restricted by being a rough surface so we will only gain from polishing or extrude honing. there are no other options.
Old Nov 10, 2005 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
You mean the front cyls
Old Nov 10, 2005 | 12:56 PM
Stephen Max's Avatar
Is it a spacer for installing between the upper and lower IM? Or is it a spacer for installing between the two halves of the 350Z plenum? If it's the latter, it won't work on our engines.
Old Nov 10, 2005 | 01:49 PM
virgilio7's Avatar
between the plenum.
you got the idea nmexmax
My native language is spanish so i get a hard time trying to explain lol
Old Nov 11, 2005 | 09:19 PM
Wil's95SE's Avatar
我爱台湾
yeah but would it be possible to have one custom made for the VQ30 and 35 Maximas? Don't we have someone on here who can fabricate it?
Old Nov 12, 2005 | 03:09 PM
kenji's Avatar
A company looked into making a new headgasket and it turned out to make little or no power. I wonder if the case is the same for this application..
Old Nov 12, 2005 | 03:13 PM
kenji's Avatar
nevermind totally different thing
Old Nov 14, 2005 | 12:56 AM
Ceasars Chariot's Avatar
Old Maxima Legend
^ u sure ? thought that was ssr engineering looking into that maybe a year back, but found not worth messing with ? who knows my memory is terrible
Old Nov 14, 2005 | 02:03 PM
gabex's Avatar
Outlaw Engineering was going to make thicker gaskets and spacers for our IM and TB. I took my car to the guy's house and he measured a few things, including temperatures between the upper and lower plenums. The end conclusion was that it wasn't necessary... that the gains are beneficial for cars that come with tiny thin metal gaskets.
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
