I might have a bad ECU!!??
Basically my car runs like $hit... i have tried everything.. one thing that is left is to check is the ecu itself... IF anybody in the chicago/schaumburg ect... area is willing to let me use try theirs PLEASE PM ME!!!
Things that have been done... new plugs, new grounds, new pcv,new tps, clean tb,clean IACV, new fuel and air filter, checked all coils, new transmission, NO CODES!!! checked injectors/fuel pump... use seafoam regularly, injectors cleaned at Dealer (is that better jeff?)
Symptoms: Bad gas milage, Huge Loss of power, hard starting (sometimes), Poor acceleration, abnormal engine vibrations when in gear...
If no one replys, and it is your car and you need to get around, there are many for 35$+ @, yes, you guessed it, www.car-part.com.
Also, you may have better luck in the regional area...
There's a good reason no one helps you. You effin' post a seperate thread every time you think you've stumbled across the "solution" to your problem. No one in their right mind is going to search all your threads and try to diagnosis your problem.
Post ALL your ideas in the ORIGINAL thread and maybe you will get somewhere. I think I've been seeing your maxima problems on and off for about 2 months!
How does it run like sh*t? Any codes? If you do need an ECU just be lucky you don't have a 5-speed. I needed a new 5-speed ECU to pass emissions and I couldn't find one anywhere(junkyards or online). I finally got enough driving history on the ECU and it passed right before the CEL light came on. I think a new one is $700 from Nissan though.
[QUOTE=Jeff92se] You effin' post a seperate thread every time you think you've stumbled across the "solution" to your problem. No one in their right mind is going to search all your threads and try to diagnosis your problem. /QUOTE]
Yea so what.. its called the PROCESS OF ELIMINATION...
[QUOTE=f550maranello2]
Agreed - except that none of us remember (since it's not our car) what the original symptoms were, what you've tried, what helped/what didn't etc. Thats why keeping one thread, with updated history at the top is useful.
I know I dont remember all your threads. Start from scratch in this thread, and list it all.
Explain why is runs bad?
what you've done
what you've checked
what you've changed
start with the basic and move up.
what you've done
what you've checked
what you've changed
You scare me. Good luck with your diagnosis
If you aren't willing to organize your problems so others can easily try to help, you're on your own buddy
If you aren't willing to organize your problems so others can easily try to help, you're on your own buddy[QUOTE=f550maranello2]
HerpDerp1919
Sep 29, 2015 02:02 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Andy29
Sep 29, 2015 05:32 AM
