What the CELl is this?
From the stickies:
0210
Diagnostic Trouble Code 0210 points to a problem with the fuel injection system. When the engine management system is running in closed-loop mode the Engine Control Unit (the computer) makes continual adjustments to maintain the air-fuel ratio near the ideal point. To achieve this it relies on signals from many sensors including the Mass Air Flow Sensor and the Oxygen Sensors.
This malfunction is detected when the ECM finds that it cannot properly control the air/fuel mixture, and the mixture is too lean (too much air). DTC 0210 indicates this problem exists on the left bank (the front bank, cylinders 2, 4, and 6). Possible causes include ...
- Intake air leaks
- Front Oxygen Sensor
- one or more fuel injectors on the front bank
- exhaust gas leaks
- incorrect fuel pressure
- lack of fuel
- Mass Air Flow Sensor
That being said, given that you only show the code for one bank, my guess would be the left bank o2 sensor is dying. Any driveability symptoms?
The reason I am ruling out a MAF or injectors is a bad MAF would affect both right and left bank and a bad injector would most likely cause misfires and/or driveability symptoms.
0210
- Intake air leaks
- exhaust gas leaks
- lack of fuel
zzznightmarezz
Sep 21, 2015 06:32 PM
