Help ASAP I bought a frankencar midpipe and dont know how to install
Originally Posted by NmexMAX
Couplers go over TB and rear end of MAF ... with the M/P in the middle.
I have everything off I put the couplers on the midpipe then add it to the throttle body then go to add the filter with the MAF and it to long and it won't bolt to my bracket under the filter
are you sure the cuplers are alllll the way in on both ends? it might save you inch or two if you do it correctly. why don't you put the franken midpipe next to your stock midpipe in that picture and show us.
ps. your filter is WIDE but it doesn't look long enough to cause the problem
Originally Posted by Mxrider52
And none of my hoses are long enough either except for that small one
Originally Posted by kormax97
You definitely need new hoses... I needed them at least. In the picture, rest looks fine to me.
How do I support the filter from dropping? There is no other brackets beside the one in the picture
I got one hose but it doesn't look long enough but oh well I give up until tomorrow or this weekend
He bought the intake from me. I sent him everything i had gotten w/ the intake except one more hose clamp which probably gotten lost. I told him that i'll get him an additional hose clamp. But as far as the hoses go, i sent him what i received from FrankenCar.
I also noticed that he isn't using the MAF adapters like i was using w/ my APEX-i cone which could decrease the length of the intake, but using the lower half of the stock airbox would help support the cone from moving as NmexMAX suggested.
He didn't get jipped, i sold the intake to him for only $50 bucks which would've costed him $80 dollars from FrankenCar w/o a filter.
You must've got jipped b/c my FC came with an extra hose to use for the IACV...
I paid 60 for my midpipe straight from frankencar, but you guys have to get all fancy and get the shiny version.
FC is weird, as I did not get the coolT bolts, but mine did come with an extra hose for the IACV hook-up ..
You write that as if you don't think i know these things ..
Srry about that buddy, I sometimes feel that i have to explain myself to ppl around here.
Yea check out Frankencars site for instructions, and for hoses you're either going to have to pick up some new ones somewhere local or see if Frankencar will send you some b/c it looks like you're missing some.
I've got a midpipe also and I only got one coupler so I had to reuse one of the stock couplers. I was also able to use some random brackets to support my filter from the strut tower to the battery tie down in this pic>>>
maxfever1987
Nov 19, 2016 08:01 PM
It will rest on the lower 1/2 of the airbox
get at least one new hose for the IACV, the crankcase vent one should be able to stretch.
