Removing Door Moldings
Old Nov 18, 2005 | 10:31 AM
mtmactom's Avatar
I have a 98 GXE which is overall in pretty good shape. But some of the adhesive on the door moldings is starting to seperate, and I was thinking of pulling them off completely. 2 questions before I attempt it.
1) are the moldings just held on by adhesive, or is their holes in the doors with plastic clips in them.
2) does anyone have any pictures of a 4th gen with the moldings removed.
I couldnt find anything covering this anywhere on the site, thats why i am asking.
Old Nov 18, 2005 | 10:37 AM
aznprid972's Avatar
I think somebody asked this awhile back and it ended up being holes underneath the molding.
Old Nov 18, 2005 | 11:18 AM
euromaxima's Avatar
yes there are holes and a v shaped groove, only way to get rid of it is to shave it. I shaved mine molding and handles, pics are at my homepage
Old Nov 18, 2005 | 01:05 PM
jman7777's Avatar
mine actually have turned a different color over time. i'm thinking about painting them back to original color. will nissan touchup paint that works on the metal be the correct type of paint to use on the plastic door moldings? anyone know?
Old Nov 18, 2005 | 01:25 PM
Nissan 6's Avatar
On My old gxe I used duplicolor on the moldings because they were a different color. I matched it with my paint code and spray painted the moldings, and they actually came out great, was very suprised by the results
Old Nov 18, 2005 | 01:45 PM
jman7777's Avatar
Sounds good. I'll have to try it, thanks!
Old Nov 19, 2005 | 07:30 AM
mtmactom's Avatar
Thanks guys, but i just found my factory service manual, and it just says double sided adhesive tape. I hope its right and you are wrong(no offense) I may just pull it and polish the door up.
Old Nov 19, 2005 | 07:38 AM
mtmactom's Avatar
Sorry guys I dont know why I would have trusted a factory manual. But I am one to always admit when i am wrong, and you guys were right, big holes and groove behind the molding.
Old Nov 19, 2005 | 02:30 PM
shavedmax's Avatar
ditto. since you pulled them off make sure you clean the moldings off goof and buy the thin 3m double sided tape. i've seen it in staples, but a body supply place would be best to buy it. i think my big roll was like 20-30 bucks
Old Nov 19, 2005 | 03:50 PM
RockfordMax's Avatar
Back from the dead
shavedmax is that a 3 TONE???!?? looks like the hood blue is lighter than the "side" blue....very nice indeed
Old Nov 19, 2005 | 04:43 PM
chillin014's Avatar
waht do they do when they "shave it" at a shop? fill in the groove with....(i forgot what its called)..laffy taffy.
Old Nov 19, 2005 | 04:49 PM
Back from the dead
Bondo....or weld in sheet metal if its a big enough area, i.e. door handles
Old Nov 19, 2005 | 07:01 PM
007max's Avatar
What they *should* do is weld in a metal plate and then smooth it out with bondo. If they just fill the whole thing with bondo it will crack and look like shit in a matter of months. Thankfully mine was done the right way
Old Nov 20, 2005 | 05:05 AM
shavedmax's Avatar
i used structural adhesive on mine so i wouldnt warp the metal. same stuff they use to glue on quarterpanels, roofs, door skins etc. it actually worked great. less grinding.first time i used it for this though so we'll see how well it holds up
Old Nov 21, 2005 | 01:13 PM
shavedmax's Avatar
thanks. no it's a 2 tone, might just be the way the light hits it. same happened with the side skirts. they look lighter than the body, but its just because they're at a different angle.
jmlee44
Oct 2, 2022 02:13 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
