Fuel Pump Issue/Relay Location
Old Nov 18, 2005 | 02:58 PM
geoff.doctor's Avatar
Well my good ole max stranded me at LaSalla bank during lunch. Missed 5th hour but got a ride back to school from a friend. Had it towed, and started playing with it. It has spark, but no fuel pressure. We pulled out the back seat, tested all 4 connections on the fuel pump with a light when turning on and starting the car, and only one had a small light (probably fuel gauge?). So I am guessing it is a bad relay. The one in the fuse box in the compartment (15A) is fine. Where are the relay(s) or fuses associated with the fuel pump? I am driving my honda, and really miss the max. Also, is this relay something I can pull from a VG, or should I buy a new one?
Thanks,
Geoff
Old Nov 18, 2005 | 02:59 PM
If it helps at all, today and yesterday are the first 20-30 degree days we have had here in Ka, Michiganl this year. Could it be weather related?
Old Nov 18, 2005 | 07:55 PM
C'mon someone has to know! I need this fixed tomorrow, its my only day off!
Old Nov 18, 2005 | 08:12 PM
disgruntled's Avatar
if you have a GXE, I would say you can pull one from a VG max. And the relay is behind the trunk lining, right where the trunk locking mechanism is at.
Old Nov 19, 2005 | 05:14 PM
internetautomar's Avatar
mod or sell?
the relay is probably the same on both cars IIRC
Old Nov 30, 2005 | 07:07 AM
93SE3.0's Avatar
Wow that is exactly what happened to my car. It didn't start, had it towed home, exact symptoms as yours. Last night I changed the fuel pump relay and it started, I drove it around to check it out let it run for about 30 min and everything was great. Come this morning it wouldn't start!! I haven't had time to look at it because I had to catch the train to get to school but needless to say I'm pissed. Did the relay fix yours? I just hate to think I have a short somewhere that's killing the relays.
Old Nov 30, 2005 | 10:20 AM
Sadly, no it did not. Fuel pump had to be replaced. Fairly easy, and only about $50 more than a new relay. With the rust, its not the most fun job though.
Old Nov 30, 2005 | 01:23 PM
93SE3.0's Avatar
Just looked at my car and there is no power getting to the relay, great. The Chilton's wiring diagram shows it coming from the computer. The computer fuses/relay are ok, so maybe the wire is broken somewhere along the line? This is frustrating, anyone offer any advice?
Old Nov 30, 2005 | 02:04 PM
92 Max's Avatar
Relay Power
I don't have the book in front of me, but I remember that the connector under the rear seat that goes to the fuel pump also goes to (or comes from ) the relay. One of the pins in that fuel pump connector should have continuity with one of the pins on the relay connector. I can't remember which ones, perhaps someone can help here. This test is in the book under the fuel pump diagnostic section.
Old Nov 30, 2005 | 05:28 PM
oldngivout's Avatar
Willing to learn
I can tell you what I had to do with my 92SE.
I had a no-start condition, but the fuel pump worked just fine with 12 volts applied externally at the connector under the seat. I traced the wire all the way from the ECU to the fuel pump relay. The wire was good, but it was not sending the signal to the relay. What it was supposed to do was complete the ground circuit on the relay coil, so that the relay would energize and run the fuel pump. This wire does not power the fuel pump, only the relay. I could never figure out why it was not working, so I just rigged it. Put a jumper wire in place of the relay, and the car ran fine.
All I lost was the 5 second safety feature, you know where the pump only runs for about 5 seconds with the ignition on and engine off. Just have to be careful and not leave the key on too long with the engine off.
Old Nov 30, 2005 | 06:14 PM
93SE3.0's Avatar
I was thinking of doing something like that but was afraid that I would start blowing fuses. My problem sounds exactly like yours oldngivout, if I can't find any solutions tomorrow I might just do what you did. I think I'm going cross-eyed from reading wiring diagrams
Old Nov 30, 2005 | 06:30 PM
oldngivout's Avatar
Willing to learn
Trust me, I did not like the way I fixed it. But it worked.
The only alternative in my case would be a new ECU, and that isn't going to happen.
Old Dec 1, 2005 | 06:14 AM
hotsoysauce's Avatar
make sure you get new fuel injector or else your a bigger pump won;t help much
Old Dec 1, 2005 | 06:50 AM
Greeny's Avatar
¯\(°_o)/¯
Huh??????....
Old Dec 1, 2005 | 02:48 PM
mod or sell?
you keep up this stupid crap of yours and I'm pretty sure they'll ban you.
you obviously lack the knowledge to give advice on this subject.
old saying:
Better to keep your mouth shut and be thought the fool than to open it and be known the fool.
BkGreen97
Apr 2, 2016 05:47 AM
bumpypickle
Sep 20, 2015 08:22 AM
rnb754
Sep 14, 2015 11:39 PM
conansriver
Sep 11, 2015 10:26 AM
