6 month old battery doesnt start car
alright i got this battery in march or april. And sometimes the car won't start. Whenever I jump start it, the car starts up with no problem. I checked the voltage of the battery. On startup with no headlights at stuff its at a constant 14.7 volts with high beam lights its at 14.375 v. Is it the alternator or what? Is there a way to check if hte alternator is running fine?
hook up a voltage meter to it...but if ur getting a constant 14.7 volts i wouldnt say alternator...unless its wierd and decides to stop working at certain points.....i would double check all connections and terminals to connectivity and corrosion first
i would say its a starter issue...so every now and then your starter is stuck in a dead spot and the extra current, and even just moving the car a bit when you open the hood and place on the cables could cause it to work again...
i find it odd that your battery would show 14.7V with a bad alternator...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
.. good idea, should have done this before you posted
