Is there anyway to aim our fogs?
Originally Posted by steven88
yes, just take off the foglight and there will be an 8mm bolt you must turn...i just recently did mine...
counter clockwise aims higher...clockwise aims lower
You don't need to take the fogs out. I had mine adjusted to point all the way up. Improves visbility a ton, lights up the signs A LOT further and I never, ever get highbeamed. Now I can actually tell when my fogs are on or off.
Originally Posted by Bluesbrekr
I'll have to check that out again. I thought the adjusting bolt adjusted them from side to side and not up or down.
oh yeah, I don't know if its just me, but I took out my housing to adjust that bolt....there might be a way to do it without taking out the housing...I just took mine out becuz you can't see **** down there!
Adjusting....
I bought OEM fogs from Custom Maxima site, they have a PDF of the install instructions which on the last page shows you how to aim the fogs after installation. If I remember correctly, all you would have to do is take the plastic guard out from the front tire well (a few grommets and a screw - 2 seconds) and then you should have access to the long-thin adjuster.
If you can't find the PDF (i think it was Custom Maxima) let me know and i'll scan my instruction book, I kept it somewhere.
Originally Posted by OutMaxxed
is the bolt on the foglight housing it self?
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
